G5 zone menu unavailable during receive
Anderegg
Enter text in this field
San Diego
Is there any way to access the zone or menu system while the G5 is actively receiving? I am finding it hard to work with this radio because I am unable to change zones because it is always receiving. I have actually had to revert to removing the antenna just to be able to change zones. :(
Paul
rr60
I have not but I simply rotate the knob to a zone position that has less activity, select the new zone THEN move channel selector Back to the number. Happens quickly once you get the hang of it.
tunnelmot
Conroe, TX
I dedicate one knob in each zone specifically for menu access and playback and record lock. When I need to change zones quickly, or replay a transmission I just rotate to the last knob position in whatever zone I'm in. You loose a knob, but it makes life WAY easier and allows you to react quickly. Also if you use this method, current live traffic wont interrupt your replays.
Anderegg
San Diego
Uggy...yeah, I may have to reserve like ch8 in each zone for zone changing. I just get so confused looking at the programming software I wasn't sure if there was a way to get it to work while receiving.
Paul
IAmSixNine
Dallas, TX
As others have pointed out. Using this as a scanner means you need to pre plan how you want to program this thing.
I learned this early on and each zone (usually knob 4 or 5) is set to a rarely used TG or group of talk groups just for this reason.
With proper programming and careful thought the G4 or G5 is a great tool for scanner people.
sparklehorse
Portland, Oregon
Unscrewing the antenna is another technique. Doesn't always work - sometimes it still receives some signal. But often it does work.
krokus
Southeastern Michigan
Have you hit the "back" button while receiving? I use that to get the soft keys back to default, but it can be a challenge to press them, before another transmission starts.
krokus
Remember these are pagers used for emergency services not scanners. I believe that design is so personnel don't miss an important life and death page while changing settings.
The audio still comes through, the display just does not show the TG name & RID. (On MPSCS, I presume the behavior would be same on any P25 trunked system.)
bob550
Albany County, NY
At least the knob position can be changed without waiting for the end of a transmission. For now, anyway. :rolleyes:
