crfitchjr,
Let us know what you have programmed in to your banks. Maybe you accidentally locked out the CC? Maybe you accidentally locked out the talkgroups you normally listen to? I know this is unlikely and doesn't really describe your problem, or your neighbors, but we'd like to help.
If you could list the LCN order you have, or provide a screenshot of your programming (win97 or other software) we might be able to assist better.
Can you manually pause on the CC and give us your decode rate (it should say a percentage in the lower corner) or let us know if, when paused on the CC, it passes the annoying data audio indicative of CCs? If not, that's a starting point, if so, cross it off the list and move on.
