- Joined
- Jan 5, 2003
- Messages
- 13,951
- Reaction score
- 9,737
- Location
- Retired 40 Year Firefighter NW Tenn
Like posted several time after it is compiled it is going to the decision makers at UNIDEN that decide to spend the money or not.
Sleep timer in SDS200 already exists....Sleep timer for the sds200.
I've been reading the posts Joe, and that's why I asked. Out of all the suggestions/issues/bug reports that have been posted, which ones fall under the "when applicable" status? I think it's a good thing to be collecting this information, but where is it really going?
| Short Name | Model(s) | Description | Source |
| J401 | SDS100 | J401 soldering | Jon Weinke |
| Hum | SDS200 | Hum on speaker | Various |
| Audio pop | SDS200 | Popping on speaker | Various/RR |
| Flickering display | SDS200 | Flickering display | Various/RR |
| SDS200 | Fuzzy display - same as above? |
| Reported | Proposed fix | FW to dept | Reported fixed | Verified |
| X | X | X | X | |
| X | X | X | ||
| X | X | X | ||
| X | ||||
It is going into a spreadsheet that will be used as each phase is entered.
Here is part of the hardware sheet:
Short Name Model(s) Description Source J401 SDS100 J401 soldering Jon Weinke Hum SDS200 Hum on speaker Various Audio pop SDS200 Popping on speaker Various/RR Flickering display SDS200 Flickering display Various/RR SDS200 Fuzzy display - same as above?
I omitted some columns like the proposed fix and checkboxes for:
Reported Proposed fix FW to dept Reported fixed Verified
Currently I think there are only a couple items on the software phase. What that phase is entered I will forward all those issues to management and work those.
They all fall under "when applicable" status. The "when applicable" part is when that phase begins.
In case you were thinking not all were applicable, that is not what that means. "When applicable" means I will not be submitting bugs (phase III) in the hardware phase (Phase I). Hardware, Software, Bugs (major then minor), then feature requests.
Did I explain it better that time?
There are a couple of critical things that, as far as I know anyway, are not covered anywhere, in neither the Uniden TWiki or ours.
How to properly program DMR (One Freq Trunk, DMR 1 through 3), MOTOTRBO (all forms), Hytera and NXDN programming (NEXEDGE / IDAS). This would apply to the 325P2 all the way to the SDS200 (with the appropriate firmware, of course). And it wouldn't hurt to include something for conventional P25 programming, too. Supplying specific examples using data from our database would go a long way in explaining this. Yes you can use a YouTube search, but some people (like me, if I had one of these radios) like a step by step approach - something that can be hard to follow on YouTube.
There are multiple streams, including multiple audio streams. You'd need a way to select what you want. And while we've had ATSC 1.0 on the air for a couple of decades now, broadcasters have started to migrate to ATSC 3.0 which is not compatible. Seems like a lot of work needed just to get TV audio on a scanner.I doubt the SDS series is capable hardware-wise due to SDR bandwidth, but someday it would be nice to have TV audio demod back in a portable receiver. ATSC channels are about 6MHz wide IIRC but not sure if the whole haystack needs to be received and decoded to just get audio or not. And whether or not that will change with ATSC 3.0 that is on the way. Wishful thinking anyway.
I could, but I also want to be careful to NOT step on toes, and it seems this is an issue for the service manager and management to decide. The person with the issue should call Customer Service and make your suggestion.
I also happen to know of one case where the scanner was 'messed with' to the point it may not be repairable (broken display, pinched wires, damaged connectors, shorted audio). In that case I believe they are going to offer a replacement unit at a discounted cost. But again that is between the service department and the customer.
BTW, that reply about a case inquiry took over a week and it was specifically due to the weather. That was stated in the reply with an apology for the delayed reply. You would normally never hear about that side of the service department adventures. (and I REALLY hope this is not the SAME CASE or I could understand the delay!!!)
I might just have to ask that question. However, even if I find it is the same case I would not post that here.
I didn't ask about this specific case, but in talking about something else I found that some parts are on order and have been for a while, so it's probable they are waiting too. (the 'something else' was about the pop issue - the last hardware issue to be addressed). I have no unit to test my theories, and neither does service currently - at least not one that has it on the FM bands.
