Help with Radio Maintenance
rbo
Quebec city
Hi! Everybody.
I had my Jaguar 700pi for a while now.It's programmed"receive only"and it's my "pride and joy".I got "auto login""unchecked"."Transmit" and "Calls" "unchecked"on all the talkgroups.Between my LID and "Prosound/Proscan"in "system setup",I put "Power"to "Low"(Even though I'm not 100% sure that this is the place to put the "transmit power"down.Everything works just fine.
My only remaining concern would be maximum "invisibility" should Mr.Controler send a command to all radios to report.What would be the steps in "Radio Maintenance" to ensure mine would'nt respond to such a request.
Things like:"Put all the deviation and power values to zero" mentionned on other posts or any thing else I should consider before making any changes in "Radio Maintenance"
Looking foward to any input from fellow members.
Thank you!
Bert.
mitaux8030
Silent Key
Home
Just unchecking auto login, transmit, calls, and don't enable any I-call functions; that will keep you off the radar just fine.
But if you're really paranoid, you can set all power levels and deviation to nothing, and physically get inside the radio and remove or disconnect the PA device... even disable the TX VCO shift function if you're really keen.
However if someone *REALLY* wanted to find you, they'd search for your RX local oscillator. That's possible, but in the 'tin foil hat' category.
rbo
Quebec city
That looks fine to me.I think i'll leave it as it is and forget about the idea to tamper with "Radio Maintenance"
Thanks for your insight!
Bert.
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
But no matter what you do, if they choose to inhibit the logical ID that is programmed into your radio, and your radio hears the command, it'll obey the command.
So, what to do...what to do...well, I don't recommend ANYTHING here, but if you were to dupe a system ID that would never be inhibited, then it would never have much of a chance of getting inhibited.
Such an ID would be, for example, the LID that comes up when a dispatch console is talking.
They're not going to disable the LID of the main police dispatch console!
Elroy
morganAL
Somerville, AL
I have actually seen a radio that someone opened up and removed the input from the modulation circuit. Even if you did key it up, it would NOT transmit the high speed data required to associate with the system. It would however still transmit a RF carrier. And yes it could still be disabled if it received the command from the CC but since it couldn't login, no one would ever know it was there.
