Help with Unication info
bobruzzo
W1AV
Cranston, Rhode Island
Here is second pic: OK....I went thru the settings on radio and got a few set.....my model number is DIFFERENT that the one we used. Not sure what to do, but I did find it in the create new profile (D) page in the software.
Yes r
OK....apparently my radios model number is G5GDG60169-SXUDENBX00-UNI-0002-230519
When I chose model number from profile it is G5B67BF-SXUDEN1401UNI so this is the model number that we used....
But looking at the model number choices I cant find mine....so should I first see if radio connects to PC then read from it?
Yes, read the radio into the PPS, go to Tab E and Read From Device at the bottom. Make sure the cable is connected (DO NOT push hard, but make sure it is attached) and turned on.
bobruzzo
W1AV
Yes r
OK first here is the model number of my radio I found in the "create new profile" (D) section of software..... and hang...gotta send u another pic....
bobruzzo
W1AV
RADIO connected to PC...no problem....and by doing a "search by connected device" it finds the same serial number as the picture I sent
OK Should I do as you said above? ready to go....
Go to the E tab and do what I said in post #142, then in the E tab, highlight the profile we set up yesterday and click on CONVERT NEW MODEL lower right, click on it and find your model.
looks like its receiving a few talk groups but no audio
Give it a little while, check volume, check E7 and change the section shown below
top three should be LOW, NO, ID Match
bottom 3 should be TONE, Speaker Off, Always
See if this helps.
Do that for each knob position, then program it again, make sure you are hitting SAVE at the bottom.
bobruzzo
W1AV
looks likeits scanning but little speaker icon in lower right corner
See if this helps.
all are set like you suggested, they were all set that way...I noticed the top button on left side of radio, when I press it in, i hear the audio....when i let go, the speaker mutes again
Please send me a screen shot of your E7 settings
