VE3RADIO
Hi Guys,
I cant for the life of me get the 296D to trunk the following system:
Metrolinx - GO Transit Trunking System, Golden Horseshoe Area, Ontario - Scanner Frequencies
I realize this is probably due to the offset being maxed out of the 296D in 752 range.. The offset for this system is 8192 and the base frequency is 380 with a 12.5 spacing. Is there any way to trick the scanner in to letting me trunk the system? It would really suck to have a 9600 baud scanner that cant track the system due to a software/firmware limitation! I heard some guys in OHIO did this for a system out that way.. if so could somone tell me what settings i should put in.
P.S. I have updated the firmware to most current.
Regards,
Matt
Regards,
Matt
