Look in the black "DOS" or "command" window on the left. You'll see at the bottom that it switches from a CAPMAX system to a CAP+ system. What frequency was it on when it froze? And maybe, if you enable CTRL -- Hunt For Lost Control Channels, it may try and find the control channel again afterwards.
Apparently you have a CAP+ site on the same frequency as one of the L1-3 frequencies. Not sure how you are going to get around that.
So enable the Hunt for Lost Control Channels, and then pay close attention to what frequency it is on when it locks up, when it starts displaying CAP+ stuff in the DOS window.
It looks like the channel that might have both a CAPMAX signal and a CAP+ signal on it might be ch 856 -- 395.325
Enabling the "Hunt for Lost Control Channels" makes it switch to another site when signal loss is detected.
It doesn't solve the problem because I stop hearing the control channel 397.175, but at least it doesn't stay idle.
Below, highlighted in red, is the capture of the moment when this happens
I believe I won't have much listening on this channel due to this issue, but there are still six other control channels left to monitor.
I appreciate the effort in trying to help me.
2024/01/24 10:18:59 DSD+ 2.457 / Fast Lane Release
2024/01/24 10:18:59 [Wagner Prevides
wagner.prevides@gmail.com]
2024/01/24 10:19:08 Base files test: All files passed
2024/01/24 10:19:08 P25 data loaded; 5 networks, 98 sites, 448 channels
2024/01/24 10:19:08 Fusion decoding enabled
2024/01/24 10:19:08 D-STAR decoding enabled
2024/01/24 10:19:08 NXDN4800 decoding enabled
2024/01/24 10:19:08 NXDN9600 decoding enabled
2024/01/24 10:19:08 dPMR decoding enabled
2024/01/24 10:19:08 DMR/MotoTRBO decoding enabled
2024/01/24 10:19:08 P25 Phase 1 and Phase 2 decoding enabled
2024/01/24 10:19:08 X2-TDMA decoding enabled
2024/01/24 10:19:08 ProVoice decoding enabled
2024/01/24 10:19:13 FMPx link established
2024/01/24 10:19:38 Freq=397.175000 Current network: L2
2024/01/24 10:19:38 Freq=397.175000 Current site: L2-1.4
2024/01/24 10:19:38 Freq=397.175000 DCC=5 From .frequencies file, line 37: Forcing TIII network type; Setting network ID, site number.
2024/01/24 10:19:38 Freq=397.175000 Current network: L1 TEST_NETWORK
2024/01/24 10:19:38 Freq=397.175000 Current site: L1-3
2024/01/24 10:19:39 Freq=397.175000 DCC=5 RAS Group call; TG=4010 Ch=856
2024/01/24 10:19:39 Freq=397.175000 DCC=5 RAS L1-3 neighbor: Site L1-9; CC=959 395.975 TEST1-4
2024/01/24 10:19:42 Freq=397.175000 DCC=5 RAS Group call; TG=4010 Ch=856
2024/01/24 10:19:42 Freq=395.325000 DCC=5 RAS L1-3 neighbor: Site L1-6; CC=1079 396.725 TEST1-1
2024/01/24 10:19:44 Freq=397.175000 DCC=5 RAS Group call; TG=4010 Ch=856
2024/01/24 10:19:46 Freq=397.175000 DCC=5 RAS Group call; TG=4010 Ch=856
2024/01/24 10:19:47 Freq=395.325000 DCC=5 RAS L1-3 neighbor: Site L1-8; CC=947 395.900 TEST113
2024/01/24 10:19:49 Freq=397.175000 DCC=5 RAS Group call; TG=4010 Ch=856
2024/01/24 10:19:51 Freq=397.175000 DCC=5 RAS Group call; TG=4010 Ch=856
2024/01/24 10:33:17 Freq=396.175000 Current network: L2
2024/01/24 10:33:17 Freq=396.175000 Current site: L2-1.8
2024/01/24 10:33:17 Freq=396.175000 Current network: L1 TEST_NETWORK
2024/01/24 10:33:17 Freq=396.175000 Current site: L1-7
2024/01/24 10:33:17 Freq=396.175000 DCC=2 From .frequencies file, line 64: Forcing TIII network type; Setting network ID, site number.
2024/01/24 10:33:17 Freq=396.175000 DCC=2 RAS Group call; TG=4010 Ch=923
2024/01/24 10:33:17 Freq=395.750000 DCC=2 RAS L1-7 neighbor: Site L1-12; CC=707 394.400
2024/01/24 10:33:18 Freq=395.750000 DCC=2 RAS Group call; TG=4010 RID=16448250 [Operador de Despacho NORTE ] Ch=923 34s
2024/01/24 10:33:53 Freq=395.750000 DCC=2 RAS L1-7 neighbor: Site L1-6; CC=1079 396.725 TEST1-1
2024/01/24 10:33:55 Freq=396.175000 DCC=2 RAS L1-7 neighbor: Site L1-10; CC=927 395.775
2024/01/24 10:33:55 Freq=396.175000 DCC=2 RAS L1-7 neighbor: Site L1-5; CC=967 396.025
2024/01/24 10:33:56 Freq=396.175000 DCC=2 RAS ACK: REG/DEREG ACCEPT Tgt=1013 Src=REGI
2024/01/24 10:33:56 Freq=396.175000 DCC=2 RAS ACK: REG/DEREG ACCEPT Tgt=7067227 Src=REGI
2024/01/24 10:33:56 Freq=396.175000 DCC=2 RAS Reg/Auth/MS Check; Tgt=7067236 Src=TSI
2024/01/24 10:33:58 Freq=396.175000 DCC=2 RAS Reg/Auth/MS Check; Tgt=7067236 Src=TSI
2024/01/24 10:34:00 Freq=396.175000 DCC=2 RAS ACK: REG/DEREG ACCEPT Tgt=9242814 Src=REGI
2024/01/24 10:34:01 Freq=396.175000 DCC=2 RAS Group call; TG=4010 RID=16448250 [Operador de Despacho NORTE ] Ch=716
2024/01/24 10:34:02 Freq=396.175000 DCC=2 RAS Group call; TG=4010 Ch=716
2024/01/24 10:34:05 Freq=396.175000 DCC=2 RAS Group call; TG=4010 Ch=716
2024/01/24 10:34:07 Freq=396.175000 DCC=2 RAS Group call; TG=4010 Ch=716
2024/01/24 10:34:09 Freq=396.175000 DCC=2 RAS Group call; TG=4010 Ch=716
2024/01/24 10:34:11 Freq=396.175000 DCC=2 RAS Group call; TG=4010 Ch=716
2024/01/24 10:34:13 Freq=396.175000 DCC=2 RAS Group call; TG=4010 Ch=716
2024/01/24 10:34:13 Freq=394.450000 DCC=2 RAS Group call; TG=800013 RID=889149 Ch=715 1s
