Icom ic-f70d
#1
I have just aquired an Icom IC-F70D radio with AES & DES encryption ready programmed with activation code via KVL keyloader enabling full encryption mode. Can anyone tell me if I can programme a second IC-F70D via an (OPC-1536) Cloning Cable to enable the encryption to work the second radio which has already been programmed for P25...Hope you get my drift as I don`t appear to have explained that very well.
Sam.
