ID Tracker II Released
brscanning
Baton Rouge, LA
ID Tracker II has been officially released. ID Tracker II basically
supports all of the features of the original ID Tracker with the following
exceptions:
- Supports the BCD396T and BCD996T scanners only.
- Supports the concept of dynamic system allocation and the use of systems
instead of banks.
- Channel descriptions are automatically retrieved from the scanner.
See version history for other information:
http://bellsouthpwp.net/k/d/kd5eis/IDTracker/IDTrackerIIVersion.htm
ID Tracker and ID Tracker II can be found here:
http://bellsouthpwp.net/k/d/kd5eis/IDTracker/IDTracker.htm
loumaag
Silent Key - Aug 2014
Katy, TX
Dave,
Thanks for your dedication to the hobby and this enhancement specifically.
scnnr
Manitoba, Canada
All I am getting is this, when I try and click on any of your links.
[FONT=Arial, Helvetica, sans-serif]Access Denied. Bandwidth limit exceeded.
[/FONT]
brscanning
Baton Rouge, LA
[/FONT]
Sorry about that. My site always takes a hit when I make a new release. The effect is usually temporary and last a few days at most.
scnnr
Manitoba, Canada
Yup, I kind of figured that is wha happened. ;)
Boomeranger
Banned
Philly burbs
Does ID Tracker II recognize PCMIA serial cards? My BCD396T is plugged into COMM 4.
I've got it working fine with ARC396 but ID Tracker II shows "Initialization Failed" error (NOT running concurrently) at any baud rate.
Help!
Andy
wjf
Witness Protection Program
Boomeranger said:
Problem solved. The comm port and the scanners baud rate were different. OOPS!
All is working fine.
Sorry about that.
Andy
I was optimistic about seeing this post. However, I still get the same error message, that being "Initialization Failed".
My baud rate and port are the same as are with ARC396.
Any ideas?
Boomeranger
Banned
Philly burbs
Any ideas?
Make sure you're using the ID Tracker II software specifically designed for the BC[39]96T scanners NOT the ID Tracker software.
I made this mistake myself early on!
Good luck,
Andy
wjf
Good luck,
Andy
Thought I did - tried again just to make sure. "Initialization failed".
Edit: Scratch that. If I told you what the problem was, you wouldn't respect me in the morning...
Boomeranger
Banned
Philly burbs
C'mon... for the benefit of others, fess up!!! ;)
Andy
wjf
Andy
Well, if I have to....
Unlike the free Uniden software, ARC396 and Advanced Virtual Control, ID Tracker needs to have "THE SCANNER TURNED ON" when starting the program.
I fall on my sword with this one.
