After cloning the osmocom OP25 repository there is a file in ......./apps/README-example-udp (duplicated below)...........
Probably best to have some prior experience installing and running OP25. You'll need two files , 1) for source audio for the voice channel, an analog audio WAV file rate 8000, mono, signed int16, and 2) trunk control channel data symbols (follow the procedures to generate this).
Max
Linking OP25 TX and RX December 2020
The OP25 TX application can be configured to transmit one or more
channels directly to one of the RX apps (rx.py or multi_rx.py) in
each case by specifying a device args string of the form
udp : host : port
where host and port are the IP address and UDP port number,
respectively. Typically, the TX is started first followed by
the RX, but they can be started in any order. UDP port 25252 is
used in the examples.
The sample RX script is in runudp.sh, and the sample TX json config
is in cfg-900.json .
To start the TX
cd .../op25/op25-gr_repeater/apps/tx
./multi_tx.py -c ../cfg-900.json
The RX is started with
./runudp.sh
There is a 120KHz sized block of spectrum transmitted (SR=120000)
which is treated as complex baseband with each side pretending that
the spectrum is converted to/from the 900 MHz band. On the RX side
any frequency-change requests are ignored; instead, a "center
frequency" is defined. There are two channels (P25 trunk control
channel and P25 voice channel) spaced at 50 KHz separation.
The TX reads two data files that must be created beforehand. To
create the trunk control channel data symbol file, refer to
tx/README-fakecc.txt
An audio file (PCM/ rate 8000 / mono / signed int16) must also be
created - this file will be real-time encoded with the voice codec
and sent on the P25 voice channel. These two files must be defined
in the cfg-900.json file (channel "source" keyword).
[/code]
