Know RAS key for a protected MotoTRBO system - Can I now listen with an SDR?
Firzen
The XPR 5XXX Kenwood Series radios with DMR at current FW don't seem to have an issue monitoring RAS enabled Mototrbo systems.
"RAS" proper is a Motorola encoding, it is not DMR standard.
If another manufacturer decides to add an equivalent of RAS to their firmware, that's up to them.
Could you tell which firmware and exact model were you using?
I’ve test NX-3720 FW 3.1.1.0 with no success.
RRR
OFFLINE
USA
Sorry, had a MOT radio right in front of me when I typed out XPR. Yes, NX-5000 Series.
Firzen
Do you remember what firmware were you using? I’m interesting if there are hardware or software difference between NX3000 and NX5000. As I said I was testing multiple way to revive RASed comm but no success. (Auto-Slot etc)
buddrousa
Here is the KENWOOD DMR listing from their site for the NX-5x00 radios.
■ DIGITAL – DMR MODE • DMR Tier 2 Conventional Option • S-Trunking Option • DMR Tier 3 Trunking Option • DMR Auto Slot Select (DASS) • AMBE+2™VOCODER • 12.5 kHz Channels • Over-the-Air Programming • Call Interrupt (Direct & Repeater Mode) • Paging Call • Emergency Call • All Group Call • Late Entry • Status Messaging • Remote Control by Subscriber Units • ARC4 Encryption Optional • Site Roaming
  • NX-5300.pdf
