TheVARailFan
I recently purchased a Laird ETRAB1550 to try on a vehicle and I am having an issue with mounting it. The antenna mounts on a modified NMO base, instead if threading on it has two guide pins that set into a track on the mount (Image attached for reference) While messing around with the mount before install it appeared to work fine, and the antenna appeared to be securely mounted. After installation, the antenna is very loose and can be knocked off with just a slight tap. I am just curious if anybody else has this antenna and has noticed the same, and if there are any tricks to getting it securley mounted.
I am also open to any alternative suggestions for a low profile VHF antenna as well, this vehicle is frequently in a parking garage with extremely low clearance that has claimed several VHF 1/4 antennas recently. If I cannot get this antenna to work I may just slap an 800mhz 1/4 wave on it and hope for the best.
Thanks in advance!
Thanks in advance!
