Every SITE is unique, and should not be joined to other sites. The freqs go in the SITE portion. All you need is the Control Channels nothing else for each site. You have ONE PRIMARY CC, and the others are ALTERNATE CC's that can be rotated to by the system for each SITE. You need only the CC's and ACC's as the BCD436HP uses what is called CONTROL CHANNEL ONLY trunk tracking. The TG's go in a list by themselves and are used at multiple sites. Some TG's are in fact statewide in use. You have ONE SYSTEM: MSWIN, You need at least ONE SITE, preferably BOTH of the SITES for your County. Then you put the TG's in their spot. Make sure all types are enabled, all the sites your going to monitor are not locked out etc... Make sure the Favorites List is set up correctly and the Quick Keys enabled if you have any set. Again: FL, System, Sites, TG's. If you wish, you can send me the hpd file and I can look at it and see what needs changed, then send it back to you.
