I tried a search and didn't find what I was looking for. Maybe I wasn't asking the right question so I am just going to post hoping I can find an answer.
I listen to mostly 800mhz in the area I am in. I primarily listen to 2 counties. I have the 800mhz rubber duckie and it works good. I wanted a mag mount in hopes of getting the other county I listen too to tune in better when in my vehicle. I live in 1 county and work in the other so I like to listen to both when driving to work and while at work.
I bought the Radio Shack mag mount and installed it on the roof of my dodge ram in front of the third brake light. I also have a cb antenna up there as well and both coax are run through the 3rd brake light. The porblem I have is I get better reception with the rubber duckie attached even when driving than I do with the mag mount. At times it the mag mount comes in fine but is usually staticy. If I change to the rubber antenna it's clear.
The mag mount is only a few days old so I don't think any connections would be dirty. I did take out the whip part and cleaned the bottom with some fine graded sandpaper as I have read that maybe there was some enamel on it being it's new but it didn't help.
The coax isn't pinch anywhere that I can see either. I thought maybe it was getting pinched by the brake light but it's good.
Any advice I could look into would be greatly appreciated!!
Forgot to add that when I turned on the local weather frequency the roof mount pulled the signal in much better than the rubber antenna. So it does seem to work for other frequencies. Just doesn't seem to be pulling in the 800mhz very well. I thought this antenna worked well for 800mhz?
