Microphonics in Kenwood HT’s
tmrva
Phoenix, AZ
I am a 2-way radio dealer with a specific problem with several radios that came in from various clients for repair. At very low volume the radios (Kenwood TK-3300 or TK-3400 series) perform fine. However when turning the volume up to a normal listening volume for a warehouse or industrial setting, the audio from the speakers of these affected units causes a feedback loop with some component in the radios, causing screeching and distortion in the audio output. Using a headset or speaker-mic solves the problem but many customers just use the HT’s as stand-alone with no headset. Is there some way anyone in the profession knows to reliably dampen the vibration and prevent the oscillation and feedback from occurring?
kd4efm
Florida
test first with a plain piece of paper behind the speaker (flat) See if that dampens the phonics.
Should be a like a black felt like backing on the coil part, but if you have felt, try that.
Also if your a KWD dealer, log into Zendesk and submit an FPR.
ramal121
Lots and lots of watts
Calif Whine Country
Wow. Two at once. I replied here...
