Mid-Atlantic MilAir 2023
TerryPavlick
Wallingford PA Villas NJ
I wonder if it is a test object for Glare 08 which is operating very close to it. Or if it is an object/target for Noble exercise that seems to be operating.
I am researching it.......while doing that found some good information on Airborne Warning Tracks....primary for AWACS
AW-700 located in W-72, altitude as assigned. Track is 12.5 NM either side of a line connecting the following Lobe Points:
a. 36°25’00”N/074°03’30”W
b. 36°25’00”N/073°26’36”W
AW-701 located in W-387, altitude as assigned. Track is 10 NM around easternmost point and 12 NM around westernmost point either side of a line connecting the following Lobe Points:
a. 36°57’00”N/072°58’30”W
b. 36°57’00”N/073°43’00”W
AW-702 located west of W-122 in the Hatteras ATCAA, altitude as assigned. Track is 12.5 NM either side of a line connecting the following Lobe Points:
a. 35°28’00”N/076°04’00”W
b. 34°52’00”N/076°42’00”W
AW-703 located in W-122 AIR 2-7, altitude as assigned. Track is 15 NM either side of a line connecting the following Lobe Points:
a. 34°47’00”N/075°22’00”W
b. 34°17’00”N/074°49’00”W
AW-710 located in W-105A, altitude as assigned. Track is 12.5 NM either side of a line connecting the following Lobe Points:
a. 40°15’00”N/072°09’00”W
b. 39°58’00”N/071°28’00”W
AW-712 located in W-107A, altitude as assigned. Track is 12.5 NM either side of a line connecting the following Lobe Points:
a. 38°40’00”N/072°44’00”W
b. 38°12’00”N/072°50’00”W
frank3si
New Castle DE
It is buzzing with activity in this area today!!!! C17 Teddy?? just landed at PHL.
Probably support for president and vice president visit to Philadelphia tomorrow.
Speaking of, does anyone have any insight/speculation as far as what aircraft may be involved in the Philadelphia trip tomorrow? I know having both the president and vice president on the same plane is generally frowned upon, but it has happened a few times in recent years. If the VC-25 is planned I'll probably drive up to a spot in NJ across from PHL to get some images.
TerryPavlick
Yes, it shows up in the legacy ADSB web address after closing the browser but doesn't show up at all in the new web address --
Okay wild guess. I thought I saw the same call sign preceding a USCG helo landing at KACY (but still trying to re-track that process)
In case that does not pan out - it is probable that the object is an aerostat.
Radarbox is showing as below and is about 10 miles off shore. If the skies clear up over the ocean - I might drive up to Long Beach Island and see if I can spot it. At least there should be no weekend beach traffic !!
I checked the Island Beach State Park live web cam and did not see anything out over the water.
TerryPavlick
National Park NJ - by any chance ?
paradiver
Middle River, MD
Looks like a sonic boom coming to Cape May, as someone is coming to play, they were showing 0.9M then pushed over 600kts. Hex was showing a P8.
TerryPavlick
That is ground speed not air speed. Before he went out of range (that direction is my poorest coverage area for now) - he was showing 356kts
