Motorola Type II Smartnet Help
budman1234
Toledo Ohio
I have two dongles but I dk if I should make one dongle have 4 vcos and to monitor the cc's I just cant figure it out lol
bravo14
Polk County FL
I have 2 dongles myself I use 1 for unitrunker 2 for dsdplus. I never got around to on unitrunker to get voice setup.
DRL-XM43
Durham Region
Can that run on windows 10?
I use it on Win 10 it runs great I use 2 dongles one for control the other for voice. If the moto has a mix of analog and digital use it in combo with DSD+ and VB Cable. If it is only analog then you don't need to.
DRL-XM43
Durham Region
You may want to start with unitrunker first to get your feet wet. Trunk88 is great but more involved to get running, although I managed to :)
DRL-XM43
Durham Region
I have unitrunker also I cant figure out how to use it with anything other than p25 lol
Enter your Motorola trunk frequency into the signal VFO if it is good that should bring up the trunk although the channels will probably be empty, wait until the list has identified the same quantity of channels as the radioreference database says it should be.
Sort the lcn colum so the control frequency matches the position of the listed frequencies, i.e if it is last in the database list, then it should be the last on the screen.
Then edit each channel and put in the frequency from the database make sure they are in the right position.
That should be it as long as you have motorola selected in UT.
