XPR Motorola XPR6350 Codeplug issues (model no. AAH55QDC9LA1AN)
Kazzeki
Hello everyone, I am a complete newbies when it comes to radio programming, I recently found a bunch of XPR 6350's thrown into a dumpster (I work for a local big pharma that apparently got an upgrade on their radios).
Now I'm a las year CS student, and I know how to get around programming, but never DMRs...
Since it is an UHF Model ( Model no. AAH55QDC9LA1AN) I got interested in reusing them for fmrs/gmrs (the latter with proper licensing of course)
I went and bought a programming cable to reprogram the radios (from BlueMax49ers) and got a hold of the CPS, but upon trying to read the radios, I get a password prompt.
Now for obvious reasons I cannot get the password. But I want to save these radios from the landfill. I read a new Codeplug from the same model could fix my situation.
From what I understand, some of you may have such password-free Codeplug that I can use on my units, and from what I understand a Codeplug doesn't count towards commercial software, so I thought of asking for it here.
I have looked on Google but no one seems to have posted such a file online.
I also searched through the sample Codeplugs, *but* the only xrp6350 Codeplug that the CPS provides in not compatible with my model, as the model number differs.
I would appreciate any help with a Codeplug or any other way to reset the radios as to make them password-free again.
I think this goes without saying but I have no need for the old Codeplug, I just want to program new frequencies into the radios.
One last thing, I do see there are services that seem to offer a way to unblock the radio from Motorola, but at $50 per radio, it's just not economically feasible for me at the moment.
Here's the radio info once again case it's needed and with more details:
NOTE: I have 2 variants on the version.
S/T: PMUE2579AANAA
IC: 109U-89FT4876
MODEL: AAH55QDC9LA1AN
VER R01.05.00. FCC ID: AZ489FT4876
And
S/T: PMUE2579AANAA
IC 109U-89FT4876
VER: R01.05.10 FCC ID: AZ489FT4876
N4KVE
PALM BEACH, FLORIDA
The feature set in both radios must be the same. Picked up a similar radio at Hamvention Saturday. Tried to also clone, but the feature set was different between the two radios. The radio I was trying to clone to did not have connect plus activaged, while the code plugs did, so connect plus had to be activated to accept the code plug.
Kazzeki
I wonder if it's possible change this or the model number via hex editor
Do you happen to have the code plug for that one? Seems mine could also have that feature enabled.
If you need to reach out to me in private please use kazzeki.dollars@gmail.com
Kazzeki
The Hex edit works. Thank you to the kind soul that messaged me the information. Now to get on with programming!
AK9R
Super Moderator
Central Indiana
I see no reason to do so. Someone else may have something to add to the topic. If not, it will just slide down the topic list as new topics are started.
marcotor
I ♥ÆS Ø
Sunny SoCal
For reference, should be able to use CPS to recover the radio. You will need the current firmware installed to your computer, and choose Device, Recover in the menu. Keep in mind doing this will write a clean codeplug, so any programming information in the radio will be lost. The good side is that you start with a clean slate.
Kazzeki
I have managed to to unlock my Codeplug. Is it against policy to share that file in case anyone else needs it in the future?
Gotcha, sorry about that
