New President Randy FCC handheld/mobile CB
Duckford
I've looked at a few reviews about it, looks like a great radio. if others in this thread indicate it is more "commercial' grade built, I might even consider one for the collection/loadout. Then again, it doesn't seem like it has many more features than my fancy CB HT, the Cobra 50 WX ST, which has channel scan, NOAA radio, instant 9 and 19, as well as a programmable "home" channel. The plastic does feel awfully cheap, and the belt clip is almost comical.
In some ways, I almost like my Uniden 401's better. Bought them for use around the property and whatnot, and the simplicity is nice for a simple "extra" radio to have around. I'll admit I like the simple aesthetic of the old fashioned red LED screen, as well.
For those of you who have one what range do you get?(including what terrain your operating it) Im definitely interested in one but it depends on range really for the price its going for.
FiveFilter
The range is dependent on the antenna and its ground plane / counterpoise. The longer the antenna, the longer the range, all things else being equal.
mrweather
Like any CB handie-talkie with the (usual) included duck antenna, the range is pretty poor. In my experience, 1/4-1/2 mile at best.
Older models ones with collapsible antennas (like old Radio Shack ones) would be better simply because the antenna is longer.
Duckford
Beyond other factors like terrain, trees, and other obstacles, we always need to keep in mind what is the other antenna? HT to HT, yes, you can have some pretty difficult times reaching far with 10/11 meter rubber ducks.
But, HT to mobile whip? Rubber duck to base station? With one strong antenna, in LOS communications, you can greatly extend the usability of CB handhelds. The increased reception and output of the bigger antenna can make up a lot for the poor performance of the stub antenna, and this can play a factor in how well they can work. If two people have CB HT's and even if ONE of them have an extended antenna, you might be surprised how much you can increase distance.
I remember testing out my Tram 1/2 length antenna, in a test configuration four feet off the ground, with one of my HT's. Walked a 1/4 mile and had a large hill completely obscuring clean line of sight, many oak trees, and no signal strength lost at all. I was tired and quit for the day at that point, but still was impressed. I need to do a better test now that the weather is better.
KD8DVR
Columbus, Ohio
I'm still working on range tests to put in a review and video review. Hard to determine, since there is such low activity around here, even if i'm literally 100 feet from I-71
cwol97401
I just got one in the mail and ordered a cobra whip antenna to go with it but forgot to get the adapter. While I'm waiting for the adapter I played with the stock antenna. Seems to have about the same range and reception as others on the market but I did notice something interesting about president's ducky. The antenna appears to have its own counterpoise coil built in essentially making it a dipole. None of my other ducky antennas look like they have one and I haven't seen a dipole on an ht since the '90s realistic telescopic antennas. I work in road construction talking to truck traffic all day long, I'm kind of concerned about the battery life but I haven't had the chance to put it to the test.
mrweather
I don't think that's a counterpoise coil but a loading coil to give the antenna the needed 1/4 electrical wavelength while physically being much shorter.
bearcatrp
Land of 10,000 taxes
No SSB so won't get one of these. FM is a nice touch though. Had a cherokee years ago. Awesome handheld. Did some good skip with it.
KD8DVR
Columbus, Ohio
Mine is working fine. I bought one of those Abbree antennas, which extend the receive range. I don't have any transmit range estimates yet, due to lack of local traffic. I know I make it to the nearest interstate, which is 100 feet away, with only a soundwall between us. It's not an all day use radio.....the battery life isn't there. I can get 10 hours or so with no transmit. Expect less time with transmitter use. Transmit and receive audio is excellent. I haven't used it on my mobile antenna, so I can't compare it...yet...to my president andy ii mobile.
slowmover
Fort Worth
Just wish side band was on the radio. Would have been the ultimate hand held CB radio.
The radio’s quality — otherwise — is what make it desirable. You seriously think you’ll be chatting on Sideband with a rubber ducky?
Short battery life makes it a temporary-use device when away from 120V for very long. A few hours is far removed from days of use (car battery powered mobile). An RV with solar electric system is a pretty good use: Randy used as backup-base or walk-about a few hours.
FM (EU version) is “the missing piece”, IMO.
bearcatrp
I used to use my cherokee on side band and chat from minnesota to alaska without issues. Still have that that antenna. Nice to do some skip when conditions are right.
