New President Randy FCC handheld/mobile CB
sloop
Lewisville, NC
Update...President electronics said that they would be announcing a drop-in charging base and mike for the Randy FCC by/at the end of June.
For all of the 'hardcore' SSBers out there....SSB on a HT is useless. I do 5 watt SSB (called QRP) on the HAM bands and without a good antenna (or mountain top) 5 watts on a rubber ducky is not going to be much better than AM (range wise) and cost a lot more. But to each their own.
slowmover
Fort Worth
Already have vehicle-mounted CB or base station that are amped + SSB. They also have DSP (which this doesn’t have). DSP would do more for it than SSB.
But those radio rigs those aren’t shirt-pocket portable. That feature doesn’t matter is qualifying reason to avoid.
Communicating with ones vehicle (as base station) plus others on AM-19 is attractive as a feature
As a backup radio in the vehicle this one couldn’t be easier to store.
I see it as adjunct to primary.
sloop
Lewisville, NC
bearcatrp...your correct. "SSB on a HT works very well depending on conditions and the right antenna. " The key is the right antenna, I was talking about a 6 to 9 inch rubber duck antenna, not a good base antenna.
bearcatrp
Land of 10,000 taxes
I used a large telescopic antenna for 27 mhz sitting in my truck with a cherokee ssb radio shooting skip to alaska from minnesota. Clear as day. Conditions were great. FM on a cb is good but not allot of cb's have FM. I still may pick one up but haven't decided. Always good to have secondary coms when no cell service. Now if someone has a hack to expand the frequencies, then I would buy one in a heart beat. 555 mhz used to be the goto freqs when running illegal cb's back in the 80's. I turn to it periodically with my receiver and don't hear squat on it now.
KD8DVR
Columbus, Ohio
Is this the correct adapter? Pretty sure it is but want to make sure. Wicox doesnt sell the adapter. Still have a couple antennas I can use with the cb. thanks
The radio also comes with the proper antenna adapter to use with a mobile antenna. The adapter you show is not the correct one for use with a mobile antenna.
bearcatrp
Got it today. Beefy radio. Charged it up so it’s ready for a 3 hour road trip to test it out. My adapter hasn’t arrived yet though. Have a older radio shack 27 MHz antenna from many years ago I wanted to use. Was a great antenna back in the day. Will see how the stock antenna works out.
KD8DVR
Columbus, Ohio
The antenna adapter should have come with the radio to let you hook it up to an outside mobile antenna. The attached antenna probably won't work too well, since the metal of the vehicle will block a lot of the signal.
