New YVR DMR Trunk
Muffin
Delta, B.C.
Does anybody know if the new MotoTRBO DMR trunk at YVR can be monitored by programming up a Motorola XPR6580 radio for recieve only? I have no desire to transmit on the trunk but I understand that the radio may wish to affiliate with the trunk.
dwc
Vancouver, BC
They are running MotoTRBO Connect Plus. I believe you would need the Connect Plus upgrade and/or option board in that radio.
Muffin
Delta, B.C.
More Specifically
Thank you - I gathered that LoL!! Perhaps I wasn't specific enough in my line of questioning - It is my understanding after reading a number of different threads that the radio affiliates with the system and the system has the ability to lock out a particular radio (ie. one that isn't part of the "authorized" users). I don't want to spending a wack of money without doing my due diligence first
mikewazowski
Forums Manager
Oot and Aboot
The radio has to be entered into the system database before it will work.
However, you can enter the frequencies in as conventional and scan it that way.
dwc
Vancouver, BC
You would be better off using the latest DSD+ fast lane and a couple of RTL dongles.
rabrol
Edmonton, Alberta
Yes, program as conventional channels and you can monitor traffic. Using dongles or a TYT with modified firmware might be the better options.
Sent from my ASUS_Z00A using Tapatalk
RayAir
Motorola radios aren't exactly great for passively scanning a Connect Plus System but if you want a portable solution instead of being tied to your computer it will work somewhat.
Program all the frequencies in twice, once for each slot but leave out the control channel (usual TS:1 of the control freq).
Program in all the TG's to your digital receive list and assign it to each channel.
You'll be limited to 16 TG's.
Muffin
Delta, B.C.
Thank you - worth a shot. There are generally less than 16 emergency-type frequencies worth monitoring anyway :)
