NX-210-K2 RR Programming Software Version?
RadioDitch
Field Operations Member
Wandering Around
Greetings all,
There's quite a few NX-210-K2's with Railroad Firmware hitting the market as a lot of railroads are dumping them for NX-5200's. So I picked a couple up. I have the cable, as well as the read and write passwords for them. But I wanted to double check which programming software is correct with the railroad firmware. Is it the KPG-111DNK? Or just KPG-111DN?
Thanks for the guidance!
kd4efm
EL98 Florida
Greetings all,
There's quite a few NX-210-K2's with Railroad Firmware hitting the market as a lot of railroads are dumping them for NX-5200's. So I picked a couple up. I have the cable, as well as the read and write passwords for them. But I wanted to double check which programming software is correct. Is it the KPG-111DNK?
Thanks!
111 IF you fw update them to normal firmware. The RR FPU is different and not available to us dealers unless we service said Class 1 RR.
Best to just dump 5.36 and let her rip.
RadioDitch
Wandering Around
Thanks for the guidance Evans! I plan on keeping them dedicated to the railroad, but wanted to be prepared. Appreciate the heads-up.
kd4efm
EL98 Florida
Truth be told, I have not seen where the RR firmware has ever gotten a face lift for that FW since it came out. Being 90% analog and 10% NXDN in small areas where it has been deployed. I can ask, see what Tech Support says, but most likely it's still the same.
RadioDitch
Wandering Around
I'm not surprised. Railroads are the one radio service where very little changes often. I know some Union Pacific NX-210K2's have normal firmware and were programmed only for the area the assigned employee works. But I know they're the odd men out.
I appreciate any info you can get.
