I'm really liking the addition of the aliased UID fields Bob.
That was a nice feature to add!
My main use of ProScan is mainly for logging purposes on several of the ProScan supported models. That feature is still working fine in the latest 8.9.0 version. Good Job!
I do have a question for the thread readers regarding using a BCD436HP via the virtual control (VC) screen remotely.
Is there a way to bring up the P25 Error/Info part of the 436 display using just a combination of buttons from the VC control screen only?
I can do this with a BCD536HP just fine via VC but have not figured out how or if it is even possible with the BCD436HP when controlling the 436HP via VC remotely using ProScan.
I know when at the actual 436, one must usually press Function and then depress the Volume knob one time and then within a few seconds, the Function button must be pressed a 2nd time and then the Volume knob must be depressed again to get the 436HP to display the P25 info screen on the radios display. It's pretty much double the amount of function and volume know pushes that it takes to get that same info displayed on the screen of a 536HP.
I run my 436HP mostly at work which is only about 1.5 miles from home. I use the feature to compare error rates from the same system but if I don't leave the 436HP set to display P25 error rates when I leave work or change systems via the VC screen, I can't make the remote 436HP show the P25 error rate screen again via the VC feature of ProScan.
I feel like I'm just not hitting the function buttons correctly on the 436 VC screen so the 436HP does not see the correct command to display that info.
I know it's a lot easier on the 536HP as one just needs to hit Function and depress Volume to bring up the P25 display but the 436 needs a 2nd Function press with a 2nd volume knob push to display that info when using the 436s keypad.
Is this P25 error/info screen able to be toggled on/off via ProScan's VC screen controls on the 436HP?
I feel like it should be able to be done and I'm simply not hitting one or more of the VC buttons when viewing my 436HP via the VC screen.
If anyone knows how to bring up the P25 Info screen with ProScan when using the 436HP via the virtual control screen, please advise the correct keystrokes needed to do it!
It's really handy info when working on the same system with two fairly identical radios located about a mile and a half apart as I can adjust the P25 threshold on the fly as long as the remote radio is on the P25 error rate/info screen.
When I'm at work, I do the same but in reverse and I can easily display the P25 info screen on the 536HP at home as well as quickly adjust P25 thresholds while a transmission is still active.
I also have remote rotor control at both ends but it's not of much use if I can't see the 436 P25 error rate screen in near realtime while at home controlling the 436 over a VPN tunnel at work and watching the physical screen on the 536 at home!
I use the info for testing various antennas as well as finding the best antenna aim when I run into simulcast timing issues when at home remotely controlling the 436HP at work.
I will admit that I never tried bringing up the P25 info screen on the 436HP with older versions of ProScan so I don't know if it was possible before version 8.9.0 or not.
When I use the 436HPs keypad to show the P25 info screen while at the radio, ProScan does display the info correctly so that makes me feel like I'm just missing a VC function button push on the VC screen or something simple or stupid that I'm overlooking.
Or maybe it is just not possible with the way the VC screen is laid out with the separate volume and squelch controls for those adjustments on a 436HP.
I do like the separate volume and squelch controls Bob gave us for the 436HP, the does make adjustments of those controls much easier than using the actual radio!
But then on the 436HP VC display, you have a Function button and what appears to be a Function control knob like the 536HP VC screen has.
The Function looking knob on the 436HP VC screen is not labeled though so I'm not quite sure of that knobs function other than possibly for scrolling through the radio's menu system. The knob appears to also have a push function that may duplicate the E/Yes button but I sure can't find the button pushes needed to bring up the P25 info display that I'm after!
Hopefully I'm just overlooking something stupid that I've missed so if anyone knows how to do what I'm after, it would be greatly appreciated if it can be explained!
