beachside
Melbourne
RSOIP MP3
Is anyone else noticing background 'clicks' when using MP3 format for RSOIP? G729 format doesn't seem to have any clicks over the same networks.
ProScan
Software Provider
Ontario, Calif.
Are the background clicks occurring when activity starts or is it at constant interval. Are you using a portable type scanner? I'm thinking the frequency response of the G729 Codec or lower Sample Per Second setting may be masking the problem.
ak4fn
Fredonia, KY
I noticed when using my bc396xt with a amplified speaker you will hear a popping sound, which I believe is the audio amplifier of the scanner engaging and disengaging and the amplified speaker amplifying the pop. I use a ground loop isolator and it helped get rid of, most of the popping sound. I wonder if the click you are hearing is the popping I'm talking about.
beachside
Melbourne
Background Clicks
I've now found restarting ProScan (server instance) stops the click and then over a day or so they slowly start again. Weird. I have isolation transformers inline. It's not related to activity and is most noticable when there's no audio. They are background clicks every second or so that I can't hear in recordings, only over RSOIP.
INDY72
Indianapolis, IN
New Bug???
Hey Bob, I may have found a bug in V 11.7
When trying to see the displayed data from the C-CH Output, I no longer get anything at all. Using an BCD396XT, with C-CH Output set to on, extended both... Nothing is displaying on the ProSCAN screen. It was working with previous version. Should I do an reinstall and see what happens?
beachside
Melbourne
I see the same thing on a 996XT.
INDY72
Indianapolis, IN
Update: On the C-CH screen, I can only see LTR data displayed, no Motorola or P25. On the tests screen I can see the Moto and P25 data scrolling but not on the C-CH screen. So yep, this is an bug.
Sent from my LG-K330 using Tapatalk
ProScan
Software Provider
Ontario, Calif.
I will look at this before the next release.
INDY72
Indianapolis, IN
Add failure to save ANY P25 NAC to the list of bugs. CTCSS and CDCSS it saves with no issues, but it now fails to save a single P25 NAC. Type in, or use the drop down to click on an NAC, hit save, and then go back to the listing after going to another group, and it is right back to NAC search.
ProScan
Software Provider
Ontario, Calif.
This one was fixed a few weeks ago.
INDY72
Indianapolis, IN
I am having it with new Del version 11.7 maybe I need to fully uninstall and start fresh
ProScan
Software Provider
Ontario, Calif.
It's not released yet. I always never uninstall. That doesn't do anything.
starneml
Lancaster, PA
Metadata Delay Question
I was thinking the Metadata delay on the Web Page was to delay the Metadata by x seconds as displayed in the graphical representation of the scanner?
It doesn't seem to be doing that for me, or I am doing something wrong.
Or is it just the textual metadata at the bottom of the webpage. (which it is doing)
Could you clarify this?
MArk
ProScan
Software Provider
Ontario, Calif.
MArk
The Metadata Delay option delays the Metadata on the Web Page. I was going to make an option to delay the Virtual Scanner display but that's on the backburner while the BCD536HP database editor is in development.
starneml
Lancaster, PA
Recording not creating mp3 files
I have recording turned on and noticed that some of the folders have mp3's in them and some don't.
But the Recorder screen is showing them as being recorded, but they cant be played back since the mp3 file isn't there.
I am using the default Recording Folders (%D\%S) and Filename format (%DT - %S - %C)
For one of the ones not working:
%S = Lancaster County-Wide Communications (LCWC) - Northwest Simulcast
%C = South Police Dispatch
So it creates the directory for the Date
Under that it creates a DIrectory named:
But it never creates a filename
DATETIME County-Wide Communications (LCWC) - Northwest Simulcast - South Police Dispatch.mp3
I thought it might have been the parens in the directory name, but if I change the Folder to %D\%C and the Filename to %DT - %C, I get folders named:
Fire-EMS Dispatch B (Northeast)
And under that a file named:
01-26-17 13-46-10 - Fire-EMS Dispatch B (Northeast).mp3
Is the length of something too long????
ProScan
Software Provider
Ontario, Calif.
Yes, the path and filename limited are limited to 260 characters
jsmn4vu
Fayetteville, GA, USA
BTW, if anyone is running ProScan on Windows 10 inside a VirtualBox environment on OSX, are you able to see the scanner when the scanner is in Serial Port mode? VB sees the radio and ProScan sees the radio's port inside Windows 10, but ProScan can't seem to talk to the radio. I'm fairly certain this is a VirtualBox thing and not a ProScan thing, but thought I'd ask here anyway.
I agree it's probably a VirtualBox issue. What I did on VirtualBox running under Linux was, under VirtualBox/settings/serial ports, checked "connect to existing pipe/socket." Then below that you'll need to enter a device from your OSX machine on the line that says Path/Address.
Hope that gets you pointed in a helpful direction; no doubt there will be better guidance on a VirtualBox forum. Good luck!
--N4VU
ProScan
Software Provider
Ontario, Calif.
BCDx36HP Favorites Support
Just a quick update on the development of the BCDx36HP Favorites Editor. Development is coming along nicely. It should be ready around mid March.
