But actually, I do see one other problem with this. If you want to manually hold on a single talk group. The scanner sits there and scans all the frequencies you have programmed in. Instead of just monitoring the 1 frequency that the talk group gets used on. There doesn't appear to be a way to tell the scanner, okay, if I manually hold on TG 10 or TG 20, then just listen to 461.4875 only. Instead, the scanner scans all the frequencies and checks 'em all, even though you're holding on just 1 talk group ID.
It's a shame Uniden couldn't have designed it be simply programming a conventional digital frequency and you just enter the slot, color code, and talk group ID all in one row.
