AC0RV
Park Hills, MO
Is there a manual or guide in using the PROSCAN Program. I am having trouble getting the program connect to the 536hp.
Please and thanks.
buddrousa
David the manual is a PDF file in the help button also located in the install folder.
What is the major problem?
I have 12 scanners connected to 12 PROSCAN installs on the same computer.
ProScan
Software Provider
Ontario, Calif.
Please and thanks.
Are you using the scanner Wi-Fi or serial port mode?
If serial port mode, put the scanner in Serial Port mode. Also install the driver. This is the Uniden link containing the serial port driver. BCD536HP < UnidenMan4 < TWiki
If Wi-Fi, where in the process are you having trouble.
gskroll
Portland, ME
Thanks - I see the page now "Copy / Move Selected History Rows" page but see no reference to creation of a Favorite List.
I did examine the contents of the default file showing under "Select File" which appears to be a comma-separated list of all "hits".
What is the process to leverage the new "History Import to Favorites" function?
ProScan
Software Provider
Ontario, Calif.
Don't select "Other File". Select Database. After clicking the Copy button, a dialog will appear prompting which existing Favorites list to copy to. Check the "New Favorite List" check box to create a new favorite list.
gskroll
Portland, ME
Thanks Bob - I was able to take only the channels & talkgroups that have been active over the last 48 hours and create “tailored” Favorite Lists omitting Systems that have not seen activity during that period.
Maybe a future enhancement could use the name fields from the history log to populate the names in the new Systems, Departments, and Channel/Talkgroups?
Thanks for your help. As others have said - there is a lot of capability in ProScan and as a new user, I have a lot to learn/discover.
tede911
Cambridge, MA, USA
Where do I find settings to change text tag justifications?
Hiya folks,
Just playing around with ProScan for the first time.
Is there an easy place to change text tag justification (justified left, centered, etc.)? Preferably all at once (ie; all tags within a group).
I find it easier to center justify all my conventional channel tags and left justify (and lower case) all my TG IDs to know what I am listening to on a quick glance.
I was able to do it in all iterations of the butel software I've owned but can't seem to find a similar option in ProScan.
Still learning the lay of the land within the software so be gentle.
Thank you!
ProScan
Software Provider
Ontario, Calif.
Hiya folks,
Thank you!
It's located in the menu Utilities - Update Text Tags.
jonwienke
More Info Coming Soon!
VA
When you click on the Audio Control tab in Normal Display mode, the scanner display disappears. It is visible with every other tab? Is there a reason for that, or can the next release not disappear the scanner display when on the Audio Control tab?
ProScan
Software Provider
Ontario, Calif.
Are you on the Monitor & Test tab? If so, that's by design as a lot of controls needs to be displayed on the same subtab. Click the Recorder, Web Server, RSOIP, or Audio Scope subtab will bring the display back.
jonwienke
VA
There is very little difference between the RSOIP and M&T tabs--mainly the Loopback checkbox and the Level radio buttons. Is the difference based on screen space, or performance?
ProScan
Software Provider
Ontario, Calif.
No, It's based on the amount of controls. Increase the height and you shall see the tone generator controls, Level meters and Level indicator options.
iMONITOR
Silent Key
S.E. Michigan
Limit to how long you can run History Log,and how big it can be?
I've been running ProScan 12.12 with the History Log open. Is there a limit to how long you can run the History Log, or how big it can be? A couple of times ProScan has locked up after running the History Log 24/7 for a few days. I know that's a lot to ask, and it's not even necessary.
I have a Dell T7810 Precision Workstation with dual 8-core Intel E5-2609v4 1.7GHz Intel processors and 32GB of RAM, 500GB Samsung EVO SSD, Windows 10 Pro 64-bit, linked to a BCD536HP scanner.
I upgraded to v 12.13 and will try it with that version and see if there is a difference.
ProScan
Software Provider
Ontario, Calif.
STS100
First look. STS100 support should be ready approx. a month or two after the retailers start selling them and I get a hold of one.
