ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
eaf1956
Evansville, IN
OK issue, If I try to run FEED along with RSOIP and Web Server ProScan will freeze and not respond. Running both FEED and RSOIP it's fine. Since I started with the Web Server, ProScan wants to not respond and freezes on my 64 Bit Win 7 Feed computer. Web Server and RSOIP have different port assignments ie 5001, 5002 they both work until the Not Responding issue occurs. Both in 14.3 and 14.4 versions.
ProScan
Software Provider
Ontario, Calif.
What do you mean by "FEED"?
What's the scanner type and using Wi-Fi?
How long does it take for the not responding to happen?
{edit} When did this start to happen?
Did Windows Update install a new video driver?
eaf1956
Evansville, IN
Broadcastify feed. Not wifi. Sds 100 And it depends if no one logs onto the web server it works ok. If it is being used I go to check it periodically and find Not Responding on ProScan.
Since I stopped the web server it has been running fine all night. Been running the Evansville feed for years with no problems, but recently started using the web server part of ProScan.
Sent from my SM-N960U using Tapatalk
Edit: The FEED Computer does nothing more than run PROSCAN. It is a Win 7 i5 core 64 bit computer. Well, it also run Norton but that's another thing. I think it mostly goes into Not Responding when I log onto the web server as a Super User.
ProScan
Software Provider
Ontario, Calif.
So it's the Web Server. Is the server serving Folders & Files?
It may be too many folders & files in the folder being served. It takes time to sort.
To turn it off for a test, click the "Clear Serve Folder Location" or set the Set Folders & Files password and not log in with that password and not log in as Supper User.
eaf1956
Evansville, IN
It's set to an empty folder, Is that an issue?
eaf1956
Evansville, IN
It's running right now. Logged on as Super User on another computer.
Try it if you'd like:
EvansvilleScanner.webhop.me:5002
eaf1956
Evansville, IN
Here is the computer I use to monitor and the feed with single display.
webstar22
RenfrewCountyScanner.com
Ontario, Canada
BOB: I was wondering if you would ever add a feature that an audio file could be played overtop of a feed, even allowing a 2nd audio input and mixing into the feed. I'm trying to do some new things with my feed and if I could do that would help. I've been trying to figure out a way to do it without.
GTR8000
NY/NJ Database Guy
BEE00
14.4 pre-release version still going strong. (y)
I do enjoy previewing the test versions, sometimes they contain easter eggs that put a smile on your face! :LOL:
eaf1956
Evansville, IN
Why is the Client Connections grid showing Edge for the browser? Is that a false detection? I primary use Chrome and haven't seen the program freeze problem. Client Connections shows Chrome here.
At this moment it has 1 connection Chrome with my local IP. The other day it had Edge and Safari connections.
alphaacres
Oswego, New York
I am having color problems with SDS100 Display in 14.4 pre-release version it will display the BCD536HP color on some of the Systems not all of them I am not using individual folders for each scanner.
