You're very welcome!Thanks for all your hard work Bob, just downloaded it.
Assuming you have created two custom folders in Program Files (x86), you can leave the third "default" ProScan install intact. Upgrade that version each time, then copy all of the files from that directory into your other two directories. That will leave all of your settings intact.Question about updating Proscan...i have two instances installed, and when i run the updater it basically creates a third. Is there a way I can update both of my instances without losing preferences, etc.?
Another way is to run the setup program then choose the same folder where one the ProScan instance is then finish the installation process. Do the same for the 2nd instance. You will not loose the configuration.Question about updating Proscan...i have two instances installed, and when i run the updater it basically creates a third. Is there a way I can update both of my instances without losing preferences, etc.?
I have Proscan 17.3 running on a mini pc. My intent is to remove the monitor and speakers. I want use remote desktop connection to connect to the mini pc running Proscan. When I remote into the mini pc I loss audio going out over web server and the computer I am remoting in on has about 5 seconds of scanner audio in a continues loop, my setup is a Uniden BCD-996XT using usb-1 and an audio cable to scanner. Both computers are Win 10 Pro.
Yes, jumps to the RR web page associated with the zip code. Enter in a zip code then click the Search button. After the the latitude, longitude, city, state, & country returns then click the RR Web Page button.Just started the trial. I have an SDS100 arriving tomorrow so I wanted to start learning how to use the software. I was curious about the search option for the RRDB import. Is the use of this to let you jump directly to the RR web page associated with a ZIP or LatLong? I didn't see information on it in the manual so I was curious.
How does the 'direct entry' work?
What does 'AID' and 'SID' stand for?
If it's in the manual, please accept my apology.
Thanks for the info on this. Is it possible to use the ZIP/LatLong search option to retrieve data on the first tab?These are RadioReference DB terms
aid = Agency ID
sid = System ID (not radio system ID but RRDB system ID)
If you already have the RRDB link that you want to import data from then enter in the aid or sid from the link (examples below) so you don't need to drill down State - County, etc..
https://www.radioreference.com/apps/db/?aid=7852
https://www.radioreference.com/apps/db/?sid=8950
I'm not sure if I am just missing it, but is there a way to view the log on the webserver? I have the Webserver service running, and have access to the recorder folder, but is there a way to show the overall log captured in the History Logging tab?
Overall, this is my first scanner (bought the the purpose of monitoring the City) and this software is a great value. 150% worth the purchase.
That's what I'm looking for, the history of radio traffic log in the webpage, without listening to it or going through the files.There's a file log "Web Server Log.txt" in the application folder. That will show when the server was started, any errors when starting, errors during run, clients online and IP address, & going offline. I don't know how useful that will be to you or what you have in mind.
History Logging is a different purpose which is history of radio traffic.
The Web Server feature doesn't have that. The RSOIP feature does have that.That's what I'm looking for, the history of radio traffic log in the webpage, without listening to it or going through the files.
That's fixed. It will be in the next version. The Downloads folder wasn't opening up. Go to the File Explorer and open the Downloads folder.Question. I get a prompt to update to 17.3 but I can't tell where it'd downloaded to to run it. ProScan used to automatically open the folder for you. After I click Finish, ProScan closes but then nothing happens after that.
