I do have ARC396 will that work? I haven't used that program in a long time. But that would have the same memory architecture.
PROSCAN will let you import the 436 files to the 325p2
IMPORT HPD and HPE FILES 1 at a time.
Ah, right, I had forgotten about the HPE Import when working with a DMA scanner. You'll have to export your 436 programming as an HPE file(s), then import those into a database you create for the 325P2.
ProScan can import directly from Favorites (hpd files) too so don't need to use Sentinel to export toYou'll have to export your 436 programming as an HPE file(s)
ProScan is the bomb...the most versatile software out there.ProScan can import directly from Favorites (hpd files) too so don't need to use Sentinel to export to hpd files.
Can you post the link to the RadioReference system? A P25 trunking system is programmed just like any other trunking system with the system type set to 'P25 Standard Trunk'.From what I have read (other than here) this is the software of choice.
BUT, I'm looking for a step by step (direct & to the point) to program a P25 trunk system into a Undien 996P2 and haven't really found anything. Anyone point me to such an animal?
It's a county government service that handles the airport & buses (neither that I'm interested in) and LRRT (Light Rail Rapid Transit) along with their police department. The database only list one 5 channel 800MHz group of channels, but looking further shows 2 or 3 other 800 groups allocated to the service.
I hard programmed those 5 in directly just to see what I hear, but found 3 out of th 5 had data transmissions on them which I took as control channels.
That's a EDACS system. Where are you getting P25 from?![]()
Niagara Frontier Transit Authority Trunking System, Buffalo, New York
Niagara Frontier Transit Authority Trunking System Profilewww.radioreference.com
Are those frequencies part of the same system? On a EDACS system, the LCN needs to be inputted with each frequency.I don't mind punching in 6 more frequencies
If you have the talk group IDs then create a group and enter them in. Set the system level parameter to 'ID Scan'. If you don't have them then set the system level parameter to 'ID Search'it's all the ID stuff that is confusing.
I think you mean frequencies and not 'channel groups'. On a trunking system, groups are TGID's and the FCC database doesn't know or care anything about TGID's.When I stated the 2 or 3 other 6 channel groups, it was NOT from this database, it was from a derived FCC database elsewhere. it may of been here;
It can't be here as this is for DMR(MotoTrbo) systemsWhen I stated the 2 or 3 other 6 channel groups, it was NOT from this database, it was from a derived FCC database elsewhere. it may of been here;
DMR Frequency Search Results
Radio frequency database search tool to identify Digital Mobile Radio, DMR, users by county and state.digitalfrequencysearch.com
Must of gotten it mixed up with something else.That's a EDACS system. Where are you getting P25 from?
I worded it wrong.I think you mean frequencies and not 'channel groups'. On a trunking system, groups are TGID's and the FCC database doesn't know or care anything about TGID's.
