ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
videobruce
Buffalo NY
Is there a way to type up or edit a text file with frequencies (no trunk) vs manually entering them via the radio? I looked at one of those data files and it looks daunting at best.
ProScan
Software Provider
Ontario, Calif.
Yes using the ProScan 'Get Clipboard' function.
Basic steps are:
1. Create a document with frequencies like. Tone, modulation, and description are optional. If scraping the data from a web page then skip this step.
851.66250, 131 DPL, PD Dispatch
859.81250, 156.7 PL, PD Tac 1
857.36250, 156.7 PL, Fire Dispatch
852.91250, 131 DPL, Public Work
2. Open or create a new database file
3. Add a conventional system
4. Add a group to the system just created
5. Click the 'Get Clipboard' menu item
6. Ensure the Delimiter Comma is selected since this list is comma delimited. If using a web page such as RadioReference then it may be tab delimited.
7. Select the items (like this) then right click mouse then choose Copy
8. Click the button '1 Get From Clipboard Everything'
9. Click the Import button
10. Close the 'Get Clipboard' window
IQ_imbalance
Sigh, i'm confused about streaming multiple feeds from ProScan. I'm running an instance for my BCT-15x and another for my SDS-200, and can run the webserver from each instance w/ a unique port number, but i'd like to be able to access the multiple streams from a single URL. Would i have to do something like pipe the input from both scanners into the windows mixer, and then somehow push that to a webserver running on one of the instances?
1808208
Hawaii
Myself.. I would run a separate web server and just create a simple home page with both feeds embedded in it. You could even run it off an old phone laying around.
ProScan
Software Provider
Ontario, Calif.
Do you want both the audio and data(data)? If so, see 1808208 response directly below your post. If you want audio only then just one instance of ProScan will work by feeding one scanner into the Left channel and the other scanner into the Right channel.
frankbreden
Riverview, Fl
I thought it was hard to program the 436, 536, 100 & 200. I am 100% lost with the ProScan I bought. Been trying for 2 day to get it up and running. trying to use 3-536 and a SDS200.
ProScan
Software Provider
Ontario, Calif.
Where are you at in the process?
Do you have the Favorites Editor opened?
Did you create a New Favorites Lists file or opened an existing file?
Are you getting the data from the RRDB?
frankbreden
Riverview, Fl
Trying to get the scanners to connect to ProScan. All have been up and running for a while. Just received the WIFI Dongles. I cannot get them to connect to the computer for broadcast.
Here I thought trying to get them set up was hard. But like anything else once you do it the more you are able to work with it.
Trying to get the 3-536's connected to stream. I will then work with the 200 with Ethernet cord for streaming.
All I am looking for is to stream them.
freqseeker
Puget Sound WA.
Here are some links that should help.
BCD536HP WIFI dongle firmware. This is from Uniden to make sure wifi dongle firmware is up to date.
BCD536hp wifi stream setup This is from the ProScan.org website. It was written by user NYRHKY94 from these forums. Very good step by step write up.
BCD536HP WIFI web server Also by NYRHKY94.
These should get you going. The SDS200 is set up the same without having to mess with the dongle.
frankbreden
Riverview, Fl
I will work on it tonite. Thank and anyone please feel free to give me advise.
frankbreden
Riverview, Fl
All I want to do is broadcast 3 scanners. I am not understanding this stuff. Do I us Radiofeed only? I have been trying for hrs to get them broadcasting.
ProScan
Software Provider
Ontario, Calif.
You can use RadioFeed if you just want to stream to Broadcastify and nothing else. ProScan and RadioFeed setup are the same. The cosmetics in RadioFeed may look a little different.
Did you setup the BCD536HP Wi-Fi yet?
Is ProScan or RadioFeed picking up the data & audio from the scanner?
frankbreden
Riverview, Fl
Bob,
It shows as broadcasting but when I g to MYRR i cannot hear it. Wifi is set up and the scanner looks to be working.
One says connected to server and the other says started to connect to Broadcastify server. It says mountpoint in use. error code 3.
ProScan
Software Provider
Ontario, Calif.
Bob,
If you can not hear it, does the Broadcastify web page show the feed as Online or Not Active?
Are you running each instance of RadioFeed or ProScan in separate folders?
The reason you are 'getting mountpoint in use' is because the instance that is giving that error is trying to connect to the same Broadcastify feed as the other instance. Do you have multiple feeds setup with Broadcastify?
ProScan
Software Provider
Ontario, Calif.
