03msc
RF is RF
The Natural State
I recommend not installing in the \Program Files or \Program Files (x86) folders for 2 reasons:
1. ProScan will put all program generated files such as the config & log files in the VirtualStore folder if not elevated to Admin mode.
2. Using the Recorder, the recordings folder & file names may exceed the 260 characters windows limitation.
I think it's best to use folders like this C:\proscan 1, C:\proscan 2, C:\proscan 3 or C:\proscan sds200, C:\proscan bcd996p2, C:\proscan bct15xt
Well, that was just an example location. I don't have mine there so I shouldn't have suggested but wanted to have a level to go up to vs just C:\. Many programs default to Program Files so that's what I chose.
03msc
RF is RF
The Natural State
Example: Here's how it could/should look (depending on how many instances you want). Note the 'breadcrumb' showing where we are on the drive [ C:\Scanner\ ]
Within C:\Scanner there are three folders in which ProScan has been installed via the program installer you downloaded from the website. Slow down and follow the steps and it will work.
03msc
RF is RF
The Natural State
Im trying to make folder s and I dont know where they should go on the computer Im really having a hard time with this, I"M SORRY
We've outlined that above. Mostly it's wherever you want (generally speaking) but not in the Program Files folder as Bob said.
ScanMaine
Lewiston Maine
When you say it isn't working (no go), what do you mean? What isn't working? Where is the 'hang up' in the process? That will help us give better guidance.
Making the file and and where to do it! That’s my issue all I see is my desktop and icons on my screen! I’m a wiz with everything else and programming but not this at all.
ProScan
Software Provider
Ontario, Calif.
Are you familiar with the Windows File Explorer? Perhaps search online for --> windows file explorer create new folder
03msc
RF is RF
The Natural State
It has been detailed in a couple of posts already. I'm not sure where you're having the issue. Making folders is simple and was described previously.
03msc
RF is RF
The Natural State
Sorry, I go to Documents!
OK so you should have an icon on your taskbar that looks similar to this on Windows 11. Click the circled icon (wherever it is on your taskbar) and you'll be in Windows Explorer. Then follow the steps we laid out previously to create the folders to then install ProScan in to.
ScanMaine
Lewiston Maine
You didn't see my post earlier? Here it is again. Search online for windows file explorer create new folder
Im NOT Followomg along, Im Sorry Im not very smart with this stuff I have said it already, What I need is someone to TALK me through and and I do it on my PC. Im not really sure why someone can't just walk me through it instead of making 500 post! I'm really sorry for all the trouble.
ProScan
Software Provider
Ontario, Calif.
This is very basic computer knowledge. Can you go to google.com then enter in file explorer create new folder like this
03msc
RF is RF
The Natural State
I dont get it. I dont see anywhere how to create a folder on my bottom task bar, Im Sorry!
This was explained in at least two posts that you've read (and responded to) already.
Right click your mouse > new folder
You DO NOT do this on the taskbar. We never said you do. You do this in Windows Explorer (the file management in Windows).
