ProScan
Software Provider
Ontario, Calif.
Folks,
I'm starting my vacation in about an hour. I should be back by the 2nd week of January. I'm going to spend time with my wife's side of the family in Cuernavaca, Mexico. I'll try to answer my emails, especially lost keys and key issues when I can. I'll try to get here when I can. I may be off the grid a few days at a time as I'm not sure where we're going each day. I do know Cancun on the 28th.
Have a Very Merry Christmas and a Happy New Year.
MayportDrone
Jacksonville, Florida
General question for anyone willing to give any input. I have been running an SDS200 with ProScan to listen on my phone remotely for about a year or so now. Everything has worked absolutely perfect. In the last couple of days. I will be listening to a broadcast and it does the lag like it just lost connection, similar to the power flickering or such. So I will try to refresh the page, getting the blank screen as in the stop button has been enabled. So, being on the road. I will call my wife. Sometimes 10-20x a day LOL. To go into the computer room to reset the scanner and app. The ProScan app on desktop will say "NOT RESPONDING." So she closes it. Restarts app and scanner and it will be fine. For who knows the amount of time. Sometimes she is asleep and can't reboot or myself when I get home from work and it starts working normal after 10 minutes or so. Was just curious what could all of sudden cause the NOT RESPONDING on ProScan and cause the freeze randomly? Thanks for any input..
Also, yes I have updated Windows and also uninstalled and re installed the software. Thanks
KC2NNS
Freehold, NJ
Next time it happens, go to the Win Mixer and see if the audio meter moves. That won't apply if using the ethernet audio on the BCD536HP and SDS200.
This issue happened again today. I checked and the audio meter is not moving when there's activity on the scanner. (not using ethernet audio)
ProScan
Software Provider
Ontario, Calif.
Can you go to the Win Mixer and see if the audio meter shows audio there. Perhaps wiggle the audio cable or swap the cable if you have another to see if the intermittant goes away.
Chris0516
Pittsboro, North Carolina
@ProScan, or for that matter, anyone. Can I use Proscan with my Analog BC75XLT? I would like to set it up to listen to the Analog communications. Just that, programming it with Proscan would be easier.
buddrousa
Did you look at the PROSCAN Site here is the list of SUPPORTED Scanners.
ProScan supports the BC125AT, BC250D, BC296D, BC346XT, BC346XTC, BC780XLT, BC785D, BC796D, BCD160DN, BCD260DN, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BCD996P2, BCD996T, BCD996XT, BCT15, BCT15X, BR330T, SDS100, SDS100E, SDS200, SDS200E, UBC125XLT, UBC126AT, UBCD3600XLT, UBCD436PT, UBCD536PT, & USDS100 scanners.
Chris0516
I did, just hoped I was missing something.
KAZ7ED
Its been a couple years, checking back to determine HomePatrol (II) support for virtual scanning?
Dragon911
Hi Bob @ProScan ,
When you get back from vacation (hope it was awesome)!
Has anyone here successfully set up ProScan with the SDS-200, particularly the server side? I'm trying to set up a stream. I'm running into network issues. (DMZ/Port forwarding /using open IP as a relay on a Netgear mesh net.) The port won't respond. I've followed both the manual and did watch a few videos on the setup. I have two issues, one appears to be with the client " I keep getting prompted1735331951354.png and the other is my network setup.
What works better? Open a support ticket or share on here?
AngWay
Curious
Buchanan, Va
can someone help me i have proscan and i have my scanner connected to it and it's recording but it shows the file as it's playing but it's notlogging it . i created a folder to save the files in but that still did not work. i will just see the recording in yellow but when it's done it goes away.
