ProScan
Software Provider
Ontario, Calif.
Ok.......When I connect the 996P2 with ProScan it shows com port on read and write
I see now. The BCD996P2 uses the protocol in the comm. port to download and upload the systems. The SDS200 doesn't have that capability because it has a SD card so the scanner has to be in Mass Storage mode(and no comm. port involved) to read and write the favorites.
buddrousa
It is like plugging up a USB jump drive they do not have COMM PORTS EITHER.
Did you Download the Serial Driver for the SDS200 from Uniden? Until you do that you will not see the SDS200 in the Virtual Display.
ninjabonez
Buda, Tx
need help plz
i cannot find toggle for Dark Mode for ProScan...
ive had it on for so long, i cannot remember where the button is -to turn on for #2 comp.
i cannot seem to find it... i know its Right There too... ready to bite me. lol
mtitteri
Lakeland, FL
New ProScan user. Sorry for the simple question. I did read the manual, but I’m missing something.
History logging…
I would like the logging window to sort rows, descending, based on time, so the list shows the last hits at a glance. As long as the scanner is continuously logging/receiving, the log looks perfect with the descending diamond on “End Date / Time“ column.
After a few seconds of silence, the log reverts back to my last selected row, somewhere down the log.
I‘ve tried the “Active Row…” options, but the log still snaps back in time and I need to manually scroll up to top. How can I force it to simply show the newest hits/rows from top to bottom?
Thank you,
Chris0516
Pittsboro, North Carolina
History logging…
Thank you,
Sort it by the 'Start Date/Time', so. The most recent appears at the top. Click on that column, and. Make sure the little 'arrow' is pointing down.
Also, On the side panel, check the box, 'Each Transmission In A New Row'.
mtitteri
Lakeland, FL
Thanks Chris, but the logging window still snaps back down the log Instead of showing the most recent loggings.
ProScan
Software Provider
Ontario, Calif.
History logging…
Thank you,
Did you try this option?
mtitteri
Lakeland, FL
Thank you Bob. I unchecked the option above and it was working perfectly for almost a page of entries, then reverted back to ‘snapping’ down the log, so new entries still needed to be scrolled back up manually for viewing.
The problem seems to happen when there’s a slew of quick, short transmissions, like my local airport tower and aircraft.
Chris0516
Are you unintentionally, sorting by 'Frequency', instead of 'Start Date/Time'? Along with having the 'Each Transmission In A New Row' unchecked?
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
History logging…
Thank you,
I run numerous instances of ProScan and one (for a BCD996XT) does this was well. I just live with it and figured I had something set wrong. It's like it stops auto scrolling.
KevinC
32D2T/957.282
Super Moderator
I'm pretty sure mine is a setting somewhere, but I think I can reliably duplicate it now. If this one instance is "always on top" or in the foreground it doesn't happen, but if it's in the background it happens. I'm going to install another instance and try it on this one radio.
KevinC
32D2T/957.282
Super Moderator
A new instance seems to have resolved my issue. The below may not make sense, but here are 2 screenshots of what's happening...
A new session of ProScan in the foreground...
And the same session after I click on something else and it goes in the background...
You can see it scrolled by itself. The history won't populate until I get a full page of hits. None of my other instances acted like this. I'll go through the other one tomorrow and see if I can find anything.
