mrkelso
NNJ
ProScan for the BCD536HP - First Look
The development is underway. The BCD536HP and BCD436HP support should be ready for beta testing end of May.
First look of the virtual scanner.
Thank GOD Bless you, Bless this program, Bless your house.
MesquiteWx
Texas
The scanner records to the SD card, so no output connection is necessary.
The record capabilities of these new scanners are not very practical. ProScan offers a much better solution to recording. You can archive recordings. You can have them save on your HD by dates and systems for later use. Plus you can listen to recordings while you continue to listen live. With the recording on these new scanners you are forced to listen to everything the scanner has saved within that set time frame you have set. You can't pause or rewind or fast forward and you can't save or listen to live audio while you're listening to recordings. With ProScan it offers much more versatility.
nyair1
Version 7.0
  • Added - Start Up Options - Added options for auto starting the Source Client, Web Server, and Scanner Over IP when program loads.
  • Added - Source Client - Broadcastify My Feed button. Click to see your feed details on the Broadcastify web site.
  • Improved - Changed the RS-232 Serial Port .Net framework control as it was causing high CPU cycles for a few users.
  • Improved - Audio meters changed from peak to RMS average values.
  • Fixed - DMA Database - Sort wasn't working if individual system was selected.
  • Fixed - Recorder Options - Prepend buffer setting needed ProScan restart to take affect.
  • Fixed - Web Server - If a "#" character was in the file name then file wouldn't server.
  • Fixed - Intermittent lockups and/or high CPU usage.
  • Many more small improvements.
ProScan supports the BCD996XT, BCD396XT, BCT15X, BC346XT, BC346XTC, BCD996T, BCD396T, BCT15, BR330T, BC796D, BC785D, BC780XLT, BC296D, and BC250D scanners.
ProScan is the most powerful and feature rich scanning software in this world.
Can't get the 7.0 update on my laptop with windows xp and also can't update my 6.8 proscan client on my work computer with windows xp?? Is 7.0 not supporting xp now? Thanks
lost_in_maine
Western Maine Mountains
what version of .net is on the XP machines? I am pretty sure you need at least 4.0 for Proscan...
I'm sure Bob will confirm the version needed..
ProScan
Software Provider
Ontario, Calif.
ProScan and Free Client all versions runs on Win XP. Did you have ProScan running on same laptop before? Do you have the Microsoft .NET 2.0 framework installed on the XP machine?
Do you get any error messages.
cg
Connecticut
Version 7.0 will not start with Remote Scanner Over IP already running. If I shut down the program with Proscan connected to my remote scanner, I used to only have to restart the program and it would remember what was running. Now I have to go to the Remote Scanner Over IP and click the start button.
chris
nyair1
I have been using the same laptop at home for about a year or more. Just tried again at work and it says "Error downloading or saving file" I belive that is the same message i get on my home computer also. I will double check again tonite.
ProScan
Software Provider
Ontario, Calif.
chris
Go to the Options ->Start Up and check the option Scanner Over IP Server Auto Start
The Start Up option was changed based on user feedback. Before the change if the connection was broken or server not running then ProScan wouldn't restart the server when ProScan loads. Now the server will start every time regardless of last state when ProScan closes..
ProScan
Software Provider
Ontario, Calif.
You can't download the ProScan version 7.0 file. Correct? What browser are you using?
nyair1
Yes i get the window popup when you load proscan and its says to click on it to download ver 7.0 When you click on that link it says "Error downloading or saving file"
I have google chrome and internet explorer 8
I have downloaded other updates in the past with my computer having these same programs without any problems.
ProScan
Software Provider
Ontario, Calif.
I don't believe there is a downloading problem on the ProScan site. Many downloads a day. Disk not full, is it?
nyair1
No i have plenty of open space. Its strange that i can't get it to upgrade on my work computer also??
nyair1
Upgrade or download? Are you running Norton Anti-Virus by any chance?
If a download problem then see if the direct link helps. http://www.proscan.org/ProScan_7_0.zip
I was trying to upgrade from 6.8 to the new 7.0 When you open up the software you get a window that opens and shows the new 7.0 ver and then you can click the download 7.0 It kept giving me a error trying to download the upgrade. I just tried it again on my radio laptop but i used internet explorer this time instead of google chrome browser. I was able to go right to the proscan site and download the 7.0 upgrade. I wonder if there is some type of problem using the google chrome browser and trying to download the update?? I will try in the morning on my work computer and see if i can download the 7.0 client through explorer to upgrade my 6.8 ver client. I will let you know how i make out. Thanks
nyair1
Forgot to mention i don't use nortons. I have the windows security essentials anti-virus
