P25 Astro Saber “Sys Wide” and Key Fail message help!!!!
spdfile1
/\/\ Junkie
Port St. Lucie,FL
Picked up a UHF Astro Saber flashed with IMBE/P25 (Flashcode is 591088-041E00-9) for a friend so he can get on P25 seeing as how he runs a UHF Quantar. Set up the code plug for it and the radio took it however when I turn the radio on after the self test displays it then shows “Sys Wide” and then “Key Fail”. Then the screen goes back to normal showing the alpha numeric tags I assigned for the channels. Also when I switch channels and transmit that “Sys Wide” display pops up and goes away. How do I get both of those to permanently go away. As far as the Key Fail I’ve set all personalities to clear under the secure tab and still no luck.
rescue161
KE4FHH
Hubert, NC
There is a key named "Sys Wide" in the Key Name section of the encryption section. Mike is correct that you should disable the encryption.
