You need either a system key OR a way around the need for a system key. It is possible to hack the CPS to ignore the absence of a system key file.
However, I neither have the instructions on how to do that nor would I publish them if I did.
Today's environment is way more paranoid than back in the days where the Astro Saber and the newfangled XTS3000 ruled supreme, when I developed both the Astro RSS out of band hack and the hidden talkgroups trick. Back then we didn't have a DHS and fears of electronic terrorism.
I just programmed one of my own radios to monitor a P25 trunked system yesterday. I did it by programming up each system channel as CONVENTIONAL digital channels, in a receive only personality, and programmed to digital carrier squelch and scan on all system channels.
Since this system is a very low traffic system, this method of programming is very nearly as good as if the radio were programmed in trunking mode for that system.
I give you that information as a suggestion. Depending on how busy the system is that you intend to monitor, monitoring it this way with conventional digital channels in scan may be preferrable because you can easily do it without even so much as denting any laws.
In any event, any Motorola trunked radio will support, at a very minimum, at least 16 separate trunked systems. In some cases, several times that. Odds are that you won't run out of capacity unless you really DO want to add in the road and bridge crews and dogcatcher's talkgroups, too.
