SDR# plugin SIMPLE DMR without audio
Ubaldo
Dear
i have AIRSPY SDR 1920 and key RTL-SDR V4 installed on two different pc but i have the same problem when i use the plugin SIMPLE DMR
i dont listen the voice, there is no audio / howewer the monitor displaying VOICE
can you halp me _
morfis
Is that version of the plugin known to work correctly with sdrsharp 1.0.0.1920?
Generally the various plugins work better with older versions of sdrsharp and the audio in particular is problematic on the newer builds.
Ubaldo
GASP !
Do you suggest me an old version (that i can find on web) of AIRSPY compatible with SIMPLE DMR ?
thewraith2008
For SDR# v1920+, there was a fix for the 'no audio' condition made for the Simple APCO and Simple DMR plug-ins.
See here
To summarize:
Go to the (MEGA) download link in the post above and open the folder Simple_APCO_DMR_PDMR
  • Download file simpleDMR_v1.1.1.0.7z and extract the two DLL files to the SDR# "Plugins" folder
  • Then download APCO_DMR_test_fix_for_v1920.7z and extract the fixed "SDRSharp.DMR.dll" file to the SDR# "Plugins" folder overwriting the existing one that was just copied there in step above.
