Portable Shortwave Receiver, which one?
Out of these three, which one would you choose?
  • Total voters
    8
  • Poll closed .
nanZor
I've done that - spent many a year putting fingernail grooves into the front faceplate paint of R-390's in another life manually tweaking as a compromise.
I think getting agc right is a significant challenge for radios designed from the start as broadcast receivers looking for steady-state or even fading signals.
It's a lot of retro-fun to ride the rf-gain, but significant issues arise like when trying to use the Grundig 750 with it's bad agc:
Airband - should be fast-attack and fast decay. Riding the rf-gain manually here is ridiculous. Lots of missed readbacks from the tower, and blown out syllables. Not really usable unless one gets this right.
Cw - same as airband: fast-attack, fast decay.
SSB : fast attack - generally slow decay.
Maybe getting that into a portable would just push the price point up too far to be profitable. Just hammering down the rf gain is in my opinion is an over the top indication that the rigs just don't know how to handle it.
Your noise level - I'll bet you've tried many different antennas. Have you tried the "loop on ground"? While not in itself some sort of magical cure, it may at least let you run with an agc again...
GB46
Well, airband, if you mean VHF, has never been a problem for me, as I live only 2 miles away from our local airport. There's lots of activity from pilot training and water bombers here during our wildfire season (the water bombers have a base at our airport). Not only that, but the tower uses only one frequency, so I have programmed my scanner with its non-functioning LCD with only that frequency. Scanning is not necessary, so there's no need to display anything.
If you were referring to the MWARA frequencies, they are very difficult to hear at my location, especially the North Atlantic routes, probably due to the mountains to the east of us, but when I do hear them I wouldn't want to decrease the gain, as they are very weak to begin with.
On the R75 I've always set both of them to fast, but the indicators only show AGC or F.AGC, so I'm not sure whether fast and slow applies to both attack and decay or not.
I have no access to the ground, hertzian, as I live on the third floor of an apartment building. It's not even possible for me to set up an outdoor antenna. The only experimentation I've done is with various lengths of random wire antennas. Currently the best one I've tried is the 23 ft. reel antenna that came with the ATS-909X. I have strung it horizontallly along an outside wall less than a foot from the ceiling (I'm on the top floor), and have added a bit of lead-in via a headphone extension cord. This way I can plug it straight into the radio's antenna jack. I also had to jury rig an adapter so that I could connect it to the R75's coax socket when I want to switch radios. It's a PL-259 connector with a very short piece of coax, at the end of which is an alligator clip on the center conductor. When I want to use the R75 I clip that to the center conductor of my makeshift antenna lead-in. It works quite well, although I actually derive very little benefit from using the R75, since the noise level is even worse that way, and the signals are no stronger than with the portable.
I never seem to have lived anywhere that's an ideal location for radio. Probably the best reception I've ever experienced was on the Canadian prairies, using the R75 with a Sony AN-1 active antenna mounted outside about 10 feet above ground. The flat terrain was a great help, but that was in the 90s, and propagation was superb back then.
shortwaver
One more vote for the 660. I love everything about it, except that it goes through eneloops pretty quick.
majoco
Stirrer
New Zealand
CW should be fast attack and slow delay - otherwise the noise comes up between words - or worse, between letters - but it's a compromise, depending on the senders' speed. Riding the RF gain still works for me, even better if you have a narrow RF or audio filter - the signal just pops out of a quiet background. You'll find most commercial radios have the RF gain on the left hand side specifically for this purpose - pity the poor leftys! Next to the handle so you have something to hang on to when the ship is rolling all over the place!
They called it "Sensitivity" here, but it does the same job....
nanZor
Oh man, don't I know how frustrating that is! I hate to see the R75 not being used. I too have lived in crappy locations, and over the years the qrm has gotten worse - so much so that even rotatable loops are not effective because nothing is a point-source anymore.
Seems like the entire neighborhood is running BPL in the homes, with only the amateur bands notched out +/- a few 100 khz each side. (At least that allows me to swl bands close to the ham bands like 41 meters, and do ATC monitoring of SFO radio on 10.057 usb.)
What I've had to do in the past was to run my R75 solely from a large-ish agm 12v battery which I recharged when necessary to totally isolate myself from the housing ac lines. That was the first step.
Then, using a portable shortwave receiver, tune it to ssb (rather than am to make hearing the noise nulls easier) and side-step inch by inch through my whole interior looking for the lowest noise. Even though it doesn't sound like it makes sense, the shortwave portable antenna was walked around in the vertical position. Eventually, I found about a 6-inch wide section where I wasn't in the immediate noise field of some noisemaker. I mean it was NARROW, but I found a spot with the portable receiver. (an Icom 817 qrp rig actually)
That is where I planted a small vertical, like a tabletop version of the "MP-1" super antenna with it's sliding coil.
Even with that, I had to make sure I choked the somewhat small coax run from the table over to it, to make sure that my coax common-mode of the shield wasn't in a noise-field.
THIS is where you could homebrew, or even something like the Apex 303-WA-2, even if indoors next to a window might help. I reviewed it here before. Basically 6 feet or so of vertical radiator, some sort of lossy wideband match, and also some sort of disconnect to make the coax less of a problem with common mode. Ie, radials don't help it either. BUT, the primary concern is to get the s/n floor down by finding a very narrow vertical position, and isolate the coax common-mode with some form of choking they use.
With the R75's double-preamps, it might just be usable in your situation.
Just some thoughts. Maybe you could tune to say 10.057 usb (to be sure you aren't in a bpl field - and frequency not critical but stay within the amateur bands for this test - even if you only do broadcast swl), keep your portable receiver antenna vertical, and side-step inch by inch through the property.
It's a pita for sure. That and running from battery like an 18 - 20ah agm you'd find in an old-school jump-starter. The R75 pulls about 900ma to 1A, so you could get about 10 hours use (about 50% discharge, which you don't really want to exceed before recharging with lead-acid worst case if you want more than a few hundred cycles from it)
Just some thought for those of us who refuse to give up! :)
nanZor
Majoco - now that's a nice receiver!
Thanks for the correction about the cw agc. Typing too late at night.
The whole agc thing just bugs me on the portables. The Grundig 750, with airband was just a pain to control manually. Differing signals strengths of incoming and outgoing planes, slow agc combined with an audio-derived squelch, rather than rf-derived just made it all too unpleasant.
Obvious solution - reach for a different tool - even the inexpensive Uniden BC75xlt scanner was like gold compared to the Tecsun S2000 aka Grundig 750.
My thought was that if it seemed like just a goof to fiddle with for an hour, and then ignore because it was just too cumbersome to enjoy, remove that feature altogether, and put the money back into the primary function of shortwave..
Stuff like that drives the radio-nerd in me nuts. But then again, I'm not really the major demographic for most marketing departments. :)
KM4OBL
Authorized Personnel
Tecsun PL-880 - Improved Now
I don't have one but from what I've read, the 660's sideband performance is better than the 880s. I wouldn't even think of the Sangean unless I was getting an enhanced version, and even then, I think the tuning step on sideband is 30hz, which is really odd..
Do some homework. We have a number of places with reviews linked here...
https://wiki.radioreference.com/index.php/Category:Receiver_Reviews
Most of the popular portables have Yahoo groups where you can ask actual owners. Don't neglect the antenna (we have a separate forum for this). A great portable will fall flat in terms of performance without a good antenna.
I recently had an opportunity to try out a PL-880, then decided on the basis of that trial to purchase one for myself, as an upgrade to the Degen 1102 I have been using for portable listening. I can confirm other reports from buyers of newer PL-880 units that the SSB performance has been improved from earlier units that are the subject of most reviews online. The AGC seems to kick in normally on SSB and be fairly stable in mine, and I don't hear any of the wobble in sound reported in reviews of earlier units.
My PL-880 is a very sensitive and selective receiver. Others have speculated that Tecsun, after issuing what they said was the final firmware update (8820), continued to make hardware and possibly firmware improvements in production without informing the public about it. In any event, I am very impressed with my PL-880 and can recommend it. The ease of storing and accessing memory presents, as well as the variable bandwidth filters and the wonderful speaker sound, are really a great improvement over my 1102.
The only problem was that I had to send my first unit back to the seller, due to one knob being misaligned, so it did not turn with the same ease all the way around its axis. Fortunately, buying from Amazon made the return easy. I recommend that you check your radio out soon after receiving it - just in case there is a quality control issue.
GB46
If you mean Broadband over Power Lines, I don't think that's in use here. We have only two ISPs available; one is the cable TV company (my ISP). The other is the phone company, which uses ADSL, and recently went over to fiber optics. What we do have in our neighborhood is giant-screen TVs, especially in our apartment building, which may be a more likely cause of RFI. I can usually tell when TVs are being switched on by the time of day. But then, I also live directly across the street from a shopping centre, and they use an excessive amount of illumination on their parking lots at night. Some of the lighting appears to be by mercury vapor, although they've converted some of the units to LEDs lately. All those lights produce lots of hash, not to mention the light pollution. An amateur astronomer would go crazy here!
10.057 mHz isn't too bad, and I can hear SFO radio at times, but very weakly, so a lower noise level wouldn't help very much. They used to come in much better on 8.843 and 6.673 in the evenings, but I rarely hear them on those frequencies these days.
As for the ham bands, they're a bit better, because sideband cuts through the noise a lot more effectively. Even there, I'm better off monitoring FT8 transmissions, as the software can often decode even what I can't hear. Some of it doesn't even show up on the S meter!
As for isolating my antenna from noise fields, I can't even find 6 inches of space for that. You were lucky!
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
This is interesting news KM4OBL- what is the serial number on your radio? That might be pertinent so that others who want to buy the 880 might have some idea of whether they're getting these improvements or not...Mike
2006walt
The Villages, FL
Has anyone tried the new Tecsun S-8800? Its double the cost of the PL-880 but has triple conversion, more expansive external antenna ports and remote control. Thanks
iMONITOR
Silent Key
S.E. Michigan
I'm pretty certain the S-8800 has been out for at least a year. The PL-880 also has triple conversion, and has an external antenna jack as well.
KM4OBL
Serial No. of My Tecsun PL-880
Serial No. of my PL-880 that seems to be working well and sounding good on SSB:
42620180600457
73 to all,
Jeff
nanZor
Also from the swling site is a listing of important keys that can drastically alter your PL880:
https://swling.com/blog/2014/06/complete-list-of-tecsun-pl-880-hidden-features/
This is really good to know, not just to see what the firmware version is, but to help restore things to normal if you get one second hand.
Although I got mine new, I accidentally put it into the wrong FM deemphasis for my area (75 vs 50us), rather quickly playing around.
Unfortunately, I have the latest firmware, and anything but pipsqueek ssb signals wobbles and distorts my agc enough to be uncomfortable. And yes, this is with playing with attenuation, not attaching 500 feet of wire to it, etc. :)
