Potomac Mills Mall VA
Outerbanks4wd
Woodbridge VA
Potomac Mills Mall went DMR in the last couple of months. Does anyone know what frequency they might be on and also type and slot assignments for DMR may be used? Thank you in advance.
TJX400
Central Virginia
Searched for the mall's name in the FCC database as well as checked for all active licenses in it's zip code with no good results.
Whiskey3JMC
DXpeditioner
40.0417240450727, -75.23614582932653
Often when businesses upgrade to DMR they keep the same frequency(ies). Try removing the analog tone info and listen via a DMR capable receiver. The known listed FCC license (linked below) contains DMR emissions. Be sure to submit confirmed findings to the RRDB
461.300466.300WQES962RM043 DPLPotMills SecSecurityFMNSecurity
463.600468.600RM723 DPLPotMills H/KHousekeepingFMNBusiness
