PRO-197 display trick!
KB9AA
Mt. Vernon, IL
Can your PRO-197 do this upside down display? Walked into the ham shack to this. Recycling power yielded better results.PRO197.jpg
KevinC
The big K
Super Moderator
1 point
And the GRE versions...
gmclam
Fair Oaks, CA
My answer is yes. I've seen the display in several "formats" including reversed (look at it in a mirror), upside down and both.
ecps92
Taxachusetts
Can your PRO-197 do this upside down display? Walked into the ham shack to this. Recycling power yielded better results.View attachment 154849
Not the upside down, but REVERSE display, when I've not resent the scanner in 30-45 days, as indicated in some prior threads.
This happens not only with the PRO but also the PSR
Simple power off, power on, then spend the next 45 min's Temp Lock out the Cable TV interference :)
fxdscon
¯\_(ツ)_/¯
Yep, reports of backwards and/or upside down displays on those scanners go back many years to shortly after they were first released.
fxdscon
¯\_(ツ)_/¯
Everybody KNOWS this you can do this with some Uniden scanners too
You're thinking of the "Set Upside-Down" setting in the Uniden menu to purposely invert the display. The scanner the OP is showing did not have a selectable setting for that, it was a random fluke of the firmware in those scanners at the time.
RMason
Colorado / Mississippi
There was a firmware revision for the PRO-197 that addressed this issue. See here: #21
Out of curiosity, what version firmware do you have?
CPU firmware version 1.8 provides the following enhancements to your Pro-106/Pro-197 trunked scanning receiver:
-Adds patch support for P25, Motorola and EDACS trunking
-Changes CCDump type string to "EDn" if "narrow invert" is turned on
-Corrects LCD “mirror image” issue
