- Joined
- Jan 5, 2003
- Messages
- 13,925
- Reaction score
- 9,693
- Location
- Retired 40 Year Firefighter NW Tenn
Neither do I but we were told by UPMan before he passed away the Priorities and Trunking on Uniden Scanners was not a good mix.
Are you scanning a trunked system and are is there more than one site set to scan?
oneIt was a 2 part question.
How many sites are programmed to scan?
Priority is offPriority will cause this as it will leave the system you are on to check the priority channel.
It only checks Priority on the system it's on and doesn't cause the issue he's seeing.Priority will cause this as it will leave the system you are on to check the priority channel.
I am talking about conventional priority, and it will indeed do what OP is describing.It only checks Priority on the system it's on and doesn't cause the issue he's seeing.
What I was trying to say was I have 3 talkgroups can those be put like tg 1 tg 2 and tg 3 while using priority id scan 1 before 2 and 2 before 3 something like that
I thought we were talking about this?I am talking about conventional priority, and it will indeed do what OP is describing.
I wasn’t. I was talking about this:I thought we were talking about this?
I noticed that when the SDS 200 sometimes the signal bar blinks on and off and where the talkgroups are blinks too then it does right are they a setting I'm missing
Did you check all of the priority settings? (Close Call, Weather Priority, Priority Scan, etc). Each of these can cause transmissions to be interruptedPriority is off
YesDid you check all of the priority settings? (Close Call, Weather Priority, Priority Scan, etc). Each of these can cause transmissions to be interrupted
