Baofeng Questions about Baofeng UV-82HP
Holdmonkey
Bryceville
Hello all! I need some help. I'm trying to find my way around this radio, and to be honest, I believe I have managed to erase all the channels that a friend programmed in for me by trying to add a frequency as a channel manually. Anyway, I am no longer able to switch back and forth between frequency mode and channel mode using the "hold the menu button down as you turn the radio on" method. Is this because I have, in fact, erased all channels so there is no channel mode to go to?
And also, is there a site I can go to that will give me this kind of information, rather than bothering y'all? In advance, I'd like to thank anyone responding. Thank you.
prima19rider
download Chirp that is what I use to program my uv-82HP. I believe you can program the stock configuration then put in what you want. I have also had good customer service from BTech.
cmjonesinc
As for the last part of your question, click the database button at the top of the page and you can select your area. After you select an area you can also choose "other agencies" or "amateur radio" to show additional information. If you are looking for something that isn't listed in the database you can ask in the region specific forums and someone may be able to help there. Welcome to radioreference.
