RG316 mobile use
SirJ
Intelligence Everywhere!
Los Angeles/Ventura County
I would rather use LMR400 if I could but that would be odd coming off a scanner.
so I’m installing a scanner in the mobile, to cut down on limited options with hiding RG58 behind panels and edges In between dash pieces I decided a simple rg316 pigtail roughly 4 feet long attached with a so239 Barrel, attached to a short run of rg58 to a Nmo mount, shouldn’t be too much loss correct?
I will be receiving/monitoring VHF low “40” mhz and some stuff up in the 700s and 800mhz range.
Running LMR400 in a mobile installation would be a royal pain in the arse.
RG-58 all the way would be just fine. No need to change cable or add connectors.
But if you wanted to, 1dB isn't going to matter much.
jcop225
Radio Zoomer
Boston, MA
For a Short run like a mobile installation I would not be too concerned. If you want to squeeze the most performance out of it go with LMR-100. Slightly larger than RG-316 and slightly lower loss, especially at higher frequencies.
Rule of thumb is you take a ~0.05dB hit for every connector so if the entire run is short enough you would be better off with small cable the entire way.
Also I'd use a SMA, BNC, TNC, etc. the performance of UHF connectors tapers off above 300 MHz.
