I have sat here and read through the whole thread. Like a limited few on here that have been inside a burning building, unless you have been there you have no idea what to expect.
Getting water on the fire. Hit the fire with water, now vision went from 2" in front of the mask to nothing, because when you hit the fire through the smoke - you got "Steam Conversion" and all of it hit your mask. The only thing you can see is tiny water droplets all over the front of your SCBA mask
With your bunker gear on, you head into the maze and search for the dull red glow for the source of the smoke and heat..
As I said above. Inside a burning structure and it is all smoke, you cannot see a thing. Doing your "Figure Eights" with your fire hose, and finally = SWOOOOOOSH , a blast of steam crowds your SCBA mask.
All the time dragging that small lifeline of a hose with you and your partner. Suddenly there is a crash and the ceiling just came down all around you.
Now what do you do?
And as I have said before.....ALOT of people have no idea what we do. Public Safety ( Fire / EMS / Police) is not what it is all cracked up to be.
The fire chief in his wise stand many years ago took the position that your radio will not be kept in an outside pocket of your bunker gear. It needs as much protection from the heat as you do. He either has the bunker gear made with an inside pocket for the radio or you wear it on your hip. The speaker mic is run inside the bunker gear. Just the mic is hanging on the neck flap of you bunker gear.
Sometime ago, maybe I would have agreed with you. But just as fast as SCBA design changes, so does the design of "Bunker Gear". Manupulating a radio with gloves on is hard and sometimes really difficult. Radio in the outside flap, and maybe the microphone clipped just outside the coat. It might get wet, but if you have a good portable ( the good ones we use, proofed to U.S. Govt standards - and ability to withstand dust and water submersion) then a portable radio on the outside of your gear should be no problem.
It doesn't take a rocket scientist to understand that that radio is your lifeline to help. It needs as much protection as you do.
I carry a radio and flashlight at all times, daylight or dark. It has been that way with me for many-many years
Those departments that just drop it into an outside pocket of your bunker gear have never been in a location where the heat has got so high that it has turned the faceplate of your SCBA dark or caused cracks to show up.
If it ever gets that hot, that my "Attack Line" cannot protect me and keep me cool enough ( keep large amount of heat to my front) to protect my SCBA mask, I need to get out of that structure.
I don't know of a radio being made today that doesn't have the time out feature included with it. But there are many radio shops that just don't take the time to program the radio with EVERY CHANNEL to have the time out timer active. This boils down to very poor control by the management over who is actually programming the radios and how they are programmed. .
I have heard some really long winded conversations on the radio, THAT needed to be broadcasted. I most always say a length of sentence ( radio broadcast ) and then I say "Break".
Saying "Break" helps the listener "digest" what has been said instead of broadcasting alot of info at once, and the person on the receivng end not "getting all" the info. It happens. A large speech at once, one large paragraph broadcased, and it is not remembered, or forgotten, no properly "processed" by the person receiving...and some parts of the radio conversation may be forgotton, misunderstood, or not heard.
Do what ever it takes to resolve your department's problem with stuck mics. It can be fixed very easily.
I believe it to be simple common sense. "Stuck Mikes" usually is because some is careless with their radio. Placing it, or positioning it where the "Transmit" button can be pushed.
Making changes in the fire service are like trying to pull a mule to the water and making him drink.
NFPA makes changes as they see fit, and they are not hard to impliment. As long as the changes start at the "PROPER" authority ( Department Chief or Deputy Chief & NFPA ) to make the change, then there is no problem.
FF - Medic !!!
