The database file seems to be the same format as the files on my computer and on the SD card. Here is the answer:
Whistler_Support said:
For those experiencing Library update issues with the GRE and RadioShack pc apps, you can download the WS1080 EZ Scan pc app and update the library then copy the contents of the DB folder to the the DB folder for your GRE or Radio Shack pc app. This takes about 1 minute.
For those that do not want to install the WS1080 EZ Scan pc app, you can go to the download page at
Downloads and select the WS1080, there you will find a Library_dbfiles_###.zip file that can be downloaded. Once downloaded you will need to unzip the file then copy the contents into the DB folder of your pc app. Updated Library versions will be posted weekly.
If download links do not show at the bottom of the page, please make sure you are using the most current version of your browser. Some browsers may have difficulty showing the links. Available downloads for the WS1080 and WS1088: EZ Scan Programming Software (WS1080Install) PC Driver...
whistlergroup.com
I also found this link while looking around......
