Scanner Communication Set-Up (Scanner Not Detected)
I have a new 396XT that I am trying to set up with ARC-XT Pro. I have set the scanner to the Baud Rate of 115200 and the correct Com-port on my computer. However, when I hit "Auto Scanner Detect" to download, I keep getting an error message that says, "SOFTWARE HAS NOT DETECTED YOUR SCANNER. PLEASE CHECK THAT YOUR SCANNER IS SWITCHED ON AND CONNECTED."
I followed the instructions given with the error message and checked the Com-Port setting on my computer. I fiddled with the USB/Serial Port connector ( I am using the included serial connector and a Gigaware USB to Serial connector).
I am still getting the error message. Any help?
ofd8001
Louisville, KY
I've had this happen to me before. What I think is going on is the comport has been captured by another software program. When ARC XT tries to access it, ARC sees it as not being available.
What I did to clear this was to do a complete computer shutdown and re-start. Then it worked fine.
Also, did you download/install the drivers for your USB to Serial connector?
OK, tried the restart, no go. Re-installed drivers. Here are screen shots of the error messages from ARC that I am getting. Also of driver info. I am running Win 10. Didn't work with Win 8.1 either.
Any other suggestions? Thanks for all your input so far guys.
