Scanning Provoice digital radio systems
APORATH
Tucson, AZ
Many cities/counties/states/entities that have trunked radio systems will sell radios on that system, with transmit features disabled and a limited channel/talkgroup list, to media agencies. That's how it's done here - the local media has portables that have no transmit capability, and only the main fire/police/EMS dispatch talkgroups, and no tac channels, special operations channels (i.e. tac team/SWAT/drug unit/EMS hospital patches/etc), and so on. This also allows the radio system operator to deal with an agency that misuses the "power" of having a radio... a quick command on the controller will turn that radio into a paperweight awfully fast... :D
Does your area use 100% encryption? just curious. My area is upgrading to a P25 system, and I don't know if the PD is going to use encryption or not.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
No, all the dispatch channels are in the clear. The special units like vice, auto theft task force, drug unit, gang unit, etc., are using either selectable encryption or full time encryption, but the media radios don't even have those talkgroups programmed in, and very very few agencies if any have scanners, P25 or otherwise.
GM
Just to clarify an issue I see on many threads about EDACS/ProVoice/Aegis trunked radio systems:
EDACS may have an End of Life for support starting in 2017, however a number of systems worldwide plan to remain on the air after that date. An "end of life" simply means the manufacturer will no longer provide support for that type of system as of the specified date. It does NOT mean that you can no longer use that type of radio/system.
Hope that clarifies this issue a bit. :)
johnls7424
Somewhere in NJ
I know the local county agency using EDACS around here is considering going to the county P25 system or going MotoTrbo
If you are referring to Middlesex County New Jersey. The answer is Project 25 Phase 2 TDMA. Migration is slowing happening now. When I say slowly I mean slowly. Tactical Public Safety ( who is contracted by the county to do maintenance on the Couny EDACS as well as upgrades) is in the process of starting to buildout and convert the analog/ProVoice EDACS system to P25 Phase 2. This migration will take a few years to fully implement.
