Ubbe
-100dBm are pretty low but should work okay. D-error are showing the number of errors in the data it decodes. When it goes up to 5 it starts to be an issue and 10 gives distorted audio and higher numbers starts to mute the audio and totally stop decoding.Decode Error 0 – 80
Receive Signal Strength Indicator -100 dBm
Continuing to experiment with filters. Does D-ERROR have units ?
The filter are 10MHz wide and you only have set a 1MHz wide spectrum when you checked for strong signals. SDS scanners receivers are not working like a "normal" scanners and any signal within 10MHz range can affect reception, that's why Uniden added the filter settings to just the SDS scanners. The Off setting are actually the normal setting that are used in Unidens other scanners. The Normal and Invert and their Wide settings are low pass and high pass filters that will attenuate strong signals above or below the monitored frequency.
The IFX setting are done to each unique frequency and will change where interference will appear in the frequency band.
/Ubbe
