Bear, thanks for the Holiday wishes. I just got up to Atlanta for the holidays. The new antenna setup works great. I started picking up Fulton County 40 miles out. My entire trip from Florida to Atlanta the entire setup worked like a champ.
Well I just finished securing all the loose wires and tighten everything down. The project only took me two days. If I ever want to restore the vehicle back to factory specs it will only take a few minutes. Nothing that was done was permeant or drilled. Another nice thing about this configuration is I'll simply swap out radios when the BCD436/536HP is released. I've already run my line for the Garmin GPS-18x.
I hope this install provided some help for those interested. I know I get a lot of ideas from others installs.
P.S. Still wish I could have drill the roof but keeping it in the garage is a must right now. That could change in a few years. :lol:
Just curious since I have a 2012 Silverado with the same setup console. I was wondering how you were able to get the stock center console insert out so you can install the Jotto Desk? I don't want to take the full center console out and have to remove the seats to get the middle plastic center piece out so I can drop the radio in
Thanks Dan: Love the setup. My truck has a stock OEM antenna where your antenna placement is. I guess the newer trucks do not have the windshield antenna anymore. I am going to find some connectors so I can tap into the stock antenna to have a low profile look.
Also the main Jotto page where I looked for the parts were going to be expensive so I went to your site that you purchased the items it was way cheaper. I will post pictures when I am done. I have been wanting to find a very professional setup and this setup is the right one for me too. Love the cup holders, its a must for sure.
Just bought the jotto desk today. Prices from SWPS.com are the lowest you will find.
1 - 425-6112 - Jotto Desk Tahoe 07+ Insert- (9"" FP) - $180.10
1 - 425-3704 - Jotto Desk Dual Cup Holder - $34.94
1 - 425-6297 - Jotto Desk BCT15 - BCD 996T - $24.86
1 - 425-6051 - Jotto Desk 2"" - Blank - $9.41
Hey wise I agree on the 536 I can't wait either But she'll setting with my other big DOG scanner my 996 ruff ruff.. Bear
The last of my install is complete. I installed a Uniden BC7 up against the firewall. There was a bracket there to mount the speaker. I went with the BC7 because it gave me the best audio and it was small in size. I tried a ESP15 and ESP 20 but I didn't like the base voice sound or how it handled Digital Audio.
I wired up the Garmin GPS-18x and added a 12vdc plug that came with a switch in the center console glove box. Seeing I will only use the GPS when heading out of town this setup works best. In the local area I will run my favorites.
Now I'm ready for the BCD536HP. It will be a simple swap out when it arrives. I plan on running the WiFi. I'll most likely install it under the center console all the way forward toward the firewall. Then I can use my iPhone as a remote head that is mounted with the Proclip on the AC vent.
Looks great!
I never understood cup holders right next to electronics. How many times have you spilt your drink
Knock on wood I have never spilt any drinks on my radios. I have since change my configuration slightly. In the original photo I had the cup holder next too the scanner so could I use my 12vdc outlets. I have since replaced the 2" blank faceplate with 2ea 1" faceplates. One is located between the scanner and the cup holder and the other is far forward to allow me to still use my 12vdc outlets. If I had the cup holder all the way forward, drinks would block access to everything.
Nice, I wish the radios where shorter so they could fit flush
