SDR# TETRA Demodulator Trunk Tracking Demonstration
thewraith2008
1.8.9, in my case it does not crash on startup, just got no sound when using the plugin.
Log:
5/8/23 ; 20:52:25.583 ; 260 ; 2101 ; 5 ; 5 ; 3612 ; 3 ; 534 ; -error! 5/8/23 ; 20:52:29.880 ; 260 ; 2101 ; 5 ; 5 ; 3612 ; 3 ; 534 ; -error! 5/8/23 ; 20:52:33.440 ; 260 ; 2101 ; 5 ; 5 ; 3612 ; 3 ; 537 ; -error! 5/8/23 ; 20:52:34.701 ; 260 ; 2101 ; 5 ; 5 ; 3612 ; 3 ; 537 ; -error! 5/8/23 ; 20:52:35.438 ; 260 ; 2101 ; 5 ; 5 ; 3612 ; 3 ; 537 ; -error! 5/8/23 ; 20:52:37.954 ; 260 ; 2101 ; 5 ; 5 ; 3612 ; 3 ; 537 ; -error! 5/8/23 ; 20:52:41.831 ; 260 ; 2101 ; 5 ; 5 ; 3612 ; 2 ; 538 ; -error! 5/8/23 ; 20:52:43.717 ; 260 ; 2101 ; 5 ; 5 ; 3612 ; 2 ; 538 ; -error! 5/8/23 ; 20:52:47.283 ; 260 ; 2101 ; 5 ; 5 ; 3612 ; 2 ; 539 ; -error! 5/8/23 ; 20:52:55.255 ; 260 ; 2101 ; 5 ; 5 ; 3612 ; 2 ; 539 ; -error! 5/8/23 ; 20:52:59.554 ; 260 ; 2101 ; 5 ; 5 ; 3612 ; 2 ; 540 ; -error! 5/8/23 ; 20:53:00.814 ; 260 ; 2101 ; 5 ; 5 ; 3612 ; 2 ; 540 ; -error! 5/8/23 ; 20:53:02.906 ; 260 ; 2101 ; 5 ; 5 ; 3612 ; 2 ; 541 ; -error! 5/8/23 ; 20:53:05.013 ; 260 ; 2101 ; 5 ; 5 ; 3612 ; 2 ; 541 ; -error!
That log does not relate to what you are seeing with no audio.
In any case, without the rule that was used to create that log, it really has no meaning to me.
What it does show is your rule most likely has a error in it's formatting.
Latest version (v1.8.9.0) can be found here: MEGA - Download
tomekjkp
Usa
Hi
Some of you may have figured out how to record audio from each instance separately to a separate folder after running several TTT instances? I'm currently using 3x TTT on one computer, but recording is only from one instance over a virtual cable Or do you have any other ideas for capturing this?
Marco192
I do not have any direct experience with your problem, but I would think that you could use multiple virtual cables, one for each instance of TTT
tomekjkp
Usa
Well, I can't, because from what I noticed, TTT only records from the cable that is set as default, if I set the microphone by default, it records what I say to the microphone during the call
Bernt112
Ukraine
I tried with Aux VFO plugin and multiple SDR Sharp with cable input but for me was don't work.
robje76
Hello,
Yesterday i have recieved my new computer. I have tried to install TTT on the computer but i can't get it working again.
I have tried the MSWINSCK.ORX in the SYSTEM folder and in the SYSWOW64 but i'll get the following error:
I'm using TTT also on my laptop, with WIN11 and it works.
Doe anyone knows what i'm doing wrong?
I'm using TTT version v1.8.9.0.
Windows 11 pro
robje76
Hello,
Windows 11 pro
I fixt it.
Re-register in the cmd solved it for me
FR33MAN
Hello again, I've been using sdr# 1716 for years, I like how that old version works because I could use TNM, TTT, aux vfo, and many more plugins. But today I decide because I'm tired of this version being blocked when I hit stop or close, I decide to try the most modern version of sdr# 1919 and I have the problem that I can't install TNM with several machine lines like we always do. My surprise is that I can't use TNM and the TTT doesn't give me sound...
Do you plan to do something in update? or can you tell me an old version of Sdr# that does not block when stopping
Thank you very much and as always very happy with the work you did and do.
I have also published this post in the TNM forum.
FR33MAN
Hello, as I told you in the other TNM forum, with version sdr#1919 I don't have TTT sound, what can I do to solve it or do you have to see how you request it with an update.
Thank you very much in advance.
Arruba
Valtournenche, VdA, Italy
Hi!
the link to MEGA is not working. Can you check?
And just in case, it will be possible to download a previous version?
Thank you
roberto aka Arruba
FR33MAN
Hello, as I mentioned in a previous post I updated to sdr#1919 and TTT does not work the audio, until they do something I want to install an old SDR# that doesn't get stuck when I press stop or close. Which version do you recommend that doesn't have crashes?
I have seen those blockades in 1716 and 1732.
Thanks in advance.
Spanish
Hola compañeros, como comenté en post anterior actualicé a sdr#1919 y TTT no funciona el audio, hasta que hagan algo quiero instalar un SDR# antiguo que no se quede bloqueado cuando le doy a stop o a cerrar. ¿Qué versión me recomienda que no tenga bloqueos?
Yo he visto esos bloqueos en 1716 y 1732.
Gracias por adelantado.
FR33MAN
Thanks in advance.
Spanish
Hello, I have been able to solve the problem with the SDR Sharp ver.1716 version by following these instructions.
The file that has worked well for me is:
(rtl-sdr-32bit-20191201).
I have renamed " librtlsdr.dll " to (rtlsdr.dll) and I have copied all the dlls to the SDR SHARP folder and I have been trying for hours and it has not stopped and every time I press stop it stops fine and I press play and It works perfectly, something that was impossible before.
Many thanks to thewraith2008 and Zeifer69.
Thanks to them I have achieved it after years with this problem.
xanadu2607
Not sure what you are trying to achieve but this thread is not the place for it as it does not directly relate to the program TETRA Trunk Tracker (TTT) or it's companion the TETRA Demodulator plug-in.
You may get better response by detailing in a posting what you are trying to do in the main forum.
Dear thewraith2008, thanks for your great work, I tried to download the latest version but found the MEGA link is not available for me, could you please send me v1.8.9.0 pack by email? please mail to: xanadu2607@gmail.com, thanks!
suco_esp
Would it be possible to reupload version 1.8.9.0? It's offline on Mega. thank you
fhebr
Hi, is there any way to listen to multiple control channels at once through TTT?
